hello everyone i was wondering as to what clutch i should put in my r33 gtr. i have recently bought this car and its now due for a major service as the clutch is on the way out i though now would be a good time to replace it.
i was looking at getting an exedy sports tuff clutch as i have heard
that they are good, keep in mind that my gtr is bone stock.
so would this be a good buy or is there something better on the market. :rolleyes:
  • Like 1
https://www.sau.com.au/forums/topic/455057-clutch-change/
The $ rules, but if it is staying stock , why not a stock or re build, they seem pretty tough or any quality single plate.
If you are going to wind it up later , I find the Nismo Coppermix Twin C Spec great , take a lot of KWs and so easy to use, spend a bit more now and save some $s later :)
https://www.sau.com.au/forums/topic/455057-clutch-change/#findComment-7502459
I've had one of these in my GT St for 11 years,no complaints from me. :-)
https://www.sau.com.au/forums/topic/455057-clutch-change/#findComment-7502491
its only going to be stock for another month or there about, so i wanted something that can handle a bit of a power upgrade and still last a while.
https://www.sau.com.au/forums/topic/455057-clutch-change/#findComment-7502524
Nismo copper mix Twin plate, standard or competition spec. Buy one and you won't regret it. NPC clutches are also good.
An Exedy Sports Tuff Clutch sounds shit and would get destroyed as soon as you start adding some power to your car.
Pay the money now for the right clutch as suggested or you'll be doing it more than once and that can be a costly procedure if you can't do them yourself.
https://www.sau.com.au/forums/topic/455057-clutch-change/#findComment-7502662
I disagree,what mods are you going to do,exhaust and maybe a couple of others the sports tuff will work well.
Can handle 300 kw at the rears and still be a comfy daily drive,butt if you want say 500 at the rears go for one of the
hyper clutches. :-)
https://www.sau.com.au/forums/topic/455057-clutch-change/#findComment-7502806
If you're staying with stock power, and driving it normally, that clutch is fine. If you're going for more power or will be launching/clutch dumping it, it will be inadequate.
https://www.sau.com.au/forums/topic/455057-clutch-change/#findComment-7502879
Like I said before look into NPC clutches and the Nismo copper mix twin plate. Both are great and will last forever basically on 300kw with track days, providing you bed the clutch in properly.
If you search the forum you will see many people use these clutches and there are only positive reviews on their performance, feel and noise compared to many other clutches including stock.
https://www.sau.com.au/forums/topic/455057-clutch-change/#findComment-7503296
Thanks ill have a look :cheers:
https://www.sau.com.au/forums/topic/455057-clutch-change/#findComment-7503307
I use the NPC 250mm organic single with 300kws and track days. But you don't launch at track days, so they're gentle on clutches. Its as easy to drive as the stock clutch. AFAIK the next step up from NPC is the carbotic, which will take more power and more punishment, but be a bit more difficult to drive. Since my GTR is no longer a daily, I would go for that now.
I think the Nismo coppermix twin recommendation is over the top for your use case, unless of course you have nothing better to do with the money.
https://www.sau.com.au/forums/topic/455057-clutch-change/#findComment-7503476
NPC have good customer service so if you call them up they can help you out if you explain what you want exactly.
I agree the Nismo would probably be over the top but depends how deep your pockets are
unfortunately my pockets aren't that deep atm.
https://www.sau.com.au/forums/topic/455057-clutch-change/#findComment-7503815
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
