So ive noticecd some mention of fire extinguishers in the car in one of the posts?
Is this compulsory? or are you talking that IF you have a fire extinguisher, it has to be securely fastened?
thanks
thanks
Compulsory
Will not pass scrutineering without one
So this is just a Skylines Australis requirement? I was at a wakefiled speed off the streets track day recently with no requirement for an extinguisher?
Where do i get one from (cheap and within 3 weeks)?
Thanks
Thanks
Most days with timing require fire extinguishers and is a requirement from our insurance
In my opinion it's piece of mind having one, could be what's stops your car burning to the ground
Supercheap auto, autobarn etc stock them on the shelf, usually only $20ish
Just make sure it's the type with metal strap and bracket and 1kg minimum
  • Like 1
ok, thanks for your help. Nice to hear they dont cost too much
I got mine from the local Big W. It's the bracket you should be more worried about (unless you're handy with metal).
I got one of those 'evok3d' ones, bolt in, works great.
I promice asking the boss tomorrow about if im able to have day off, tax has cleared so entry can be paid, and maybe some coil overs and tires for the 32 ;)
  • Like 1
Yeah ive had a bit of a look and actually the cheapest ones seem to be at Bunnings and the one ive gone for is from Officeworks! Didnt check Big W but too late now.
See you guys in a few weeks :cheers:
Just to be clear, your car WILL be scruitinered.
That means, someone will look over it for leaks, loose items in the cabin/boot, sufficient tyre tread, brake operation, battery secured (big one! With metal, not zipties!), seat belt condition and operation.
If you are unsure about any of these things, please ask, and/or get it sorted before turning up on the day :)
  • Like 1
Paid in full. Sorry for late pay but have confirmed i am free that day.
On another note will my car fail for having rat crap in it, apparently parking your race car on a property is not the best storage :glare:
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
