I never had the fuel under 1/3rd , they told me not to go below 1/4 until I get a surge tank if I am going to push t a little,
I suggest to get this sorted before you take it again, not nice play Russian roulette with a new motor.......
  • Like 2
It's not the valve springs is it.. Those cam lobes are very aggressive
Same springs and retainers as what's in mine. There shouldn't be an issue unless there was a mega mess up installing.
Having said that, if it's coughing in neutral, it won't be springs as there is no boost.
t will all be done and I will be very careful until it's done.I never really push it under half full and my pushing is not like you blokes drive :)
Things are looking up, my builder called me and we were talking about the car and he has put in a starter motor for free and going to run a 3.5" Dump and Cat for me "no Charge" so it will be 3.5" all the way. That was a great offer :banana:
Just a matter of finding out where the water is going , a re tune and off we go :)
  • Like 4
Good work Pete, when do they think you'll have it back with a new and improved tune?
Hi James, not sure mate, but I would think he will do it ASAP, might get rid of a bit of back pressure and and flow better ?
Depends on the DBs if I will look at a quieter muffler that still flows but I will wait and see how it sounds and go from there as this exhaust was pretty quiet, well quieter before the build :/
NO, I free revved it and sitting on 5500rpm it started farting.
They have to work it out, all they have to do is drive it , they will fix it, no problem :)
I just wonder if they tweaked it yesterday on the dyno, it never went over 7000rpm without sounding like you hit the limiter but it is set at 8500rpm
doesn't have a neutral Rev limiter does it?
Factory ecus do it, should be possible to program it.
No mate, I am running a new Haltech Platinum Pro 34GTR and the limiter is set at 8500rpm.
I think it has a limit of 4 or 5000rpm until the motor is running at a normal driving temp around 70 degrees. I never drove the car hard until it was hot.
Got me stuffed, ran to 8000rpm + on the Dyno when being tuned and when I just took it into Sydney on Monday :/
But it will be fixed soon and I will be a happy camper :camping:
Holy crap!!
They must be reading this thread haha
Let's hope so, so many injustices here.
Good Pete, glad they are making things right for you.... As they should. Make sure you post up vids when you get it back.
Great news, Pete!
Will they be doing the flex tune and winding it up to see what numbers this can punch out?
Not having it done yet, I am still trying to work out what I will do with the car after I get it back and see how it is going
I always said they would fix any of the problems, shit happens and after you have waited for a build to be finished and run into a few probs when you get it back it gets you frustrated, living so far away just adds to the frustration :yes:
It will be interesting to see what difference the 3.5" dump and cat make when it is being tuned ?
You'll break 400kw with it I bet.
You'll see how much difference a good dump does.
Yeah i agree i just had a good dump! Feel so much lighter! :D
Great news on the car Pete i think thats the least they coulda done being the high end customer you were! Your build wasn't exactly a budget build so why they left pieces of the puzzle out like dump pipes etc before the tuning process was beyond me?!
  • Like 3
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
