@Leroy Peterson, can you give us some more info? Where did you find this? it looks to be in amazing condition.
Are you into English cars or did this just peak your interest this time? I'd love to hear the background to this.
19 hours ago, Steve85 said:
Leroy! My god! That's gonna hurt... I hope you are good with electrics! did you get a warranty? (jk).
I bet he's shopping for that warranty before attempting to do anything to it :P
  • Like 1
I've decided to keep track of the build here: http://www.zeitakuvip.com/forum/member-s-rides/non-vip-builds/22023-triumph-tr7
After the whole Photobucket fiasco, i dont really want to be posting on multiple forums again... except some odd updates on the pulsar on SAU. All the detail is on PGA.
Everyone carrying on about rust has me real worried about the car. like how do you wash a car that rusts easily? cant use water lol. It also will be sitting outside for a week or two which has me concerned... ill buy a cover for it I think
  • Like 1
11 hours ago, Leroy Peterson said:
Thanks for putting that link up. I'll be lurking in the background (like always!).
3 hours ago, Leroy Peterson said:
Yeah dolomite sprint. Think it needs a lot of work. Might have been a parts car.
Doesn't look too rusty on the surface.
Once you dig deeper...
I'm tempted to look at it haha
On 12/08/2017 at 3:41 PM, Count Grantleyish said:
Whoa, I'm seeing double!
Haha, one is silver, one is white. Also one is knackered (gearbox issues) and one is in mint condition...
  • Like 1
2 minutes ago, Count Grantleyish said:
Gearbox issues, is it under warranty?
Silver one is knackered. It has just become my daily, i've had it for two years and it has served me well so far. It's certainly not under any kind of warranty.
The gearbox had a it of a meltdown about 3 or 4 months ago and was flaring and carrying on. I ignored it (like you do) and then finally at the service mentioned it was "a bit rough". They recommended a new gearbox for 10k. I declined and we looked at the new models, but none of them were my thing. In the end, we came back to the same model, only this one has been well kept, well serviced and has every conceivable option these things came with.
If the gearbox does go, it will be a project for my friends and I to change it over and see if we can reprogram the car. Surprisingly it has been very well behaved since the initial problems, but i'm pretty much expecting it to stop moving the back wheels at any stage now. When it does, bring on the spanners... :)
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
