I trashed mine at a bar all day everyday for a year before it was stolen. It will break eventually. Just be prepared for when it does and thank god you don't have a 26 that takes the motor with it
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
