Hi all,
Have purchased the sandwich plate for my sensors (oil and pressure)
P
The plate costed 20 and it is unbranded but has oring on the side it is linking to the filter but no oring on the side which makes connection with the engine base
So question is , is that ok ? I have seen numbers of them on youtube and seems like you dont need an o ring or sealent on the connection to the base .
Also there is no o ring for the bolt holes ,there is 3 holes , 2 of which will be used for temp and pressure gauge and one blanked off.
Is that ok again with no o ring etc?
Re earth connection i guess any cable to the engine base will do ?
https://www.sau.com.au/forums/topic/456086-oil-sandwich-plate/
This is. Pic of my item ( i bought it from same listing)
http://m.ebay.co.uk/itm/301603288304?nav=SEARCH
So it has 2 sides one with oring and one flat
The flat will connect to filter and obribg to base?
How about the bolts? Do they need oring or sealent
Ok so how the first photo is is how it goes on, the bolt/nut goes through the plate and bolts to the thread the filter screws to then the filter screws to the thread you can see in the first pic, i can only see the first pic
The plate has O-ring same as filter which seals against block the filter has O-ring that seals against plate, the blot/nut will have a O-ring that will seal against the plate also
As Mick said for the plate, the bolts I'm assuming you mean the 2 blanking bolts that came with it? and any sensors you screw in, they're NPT thead which naturally make a fluid-tight seal as you tighten them.
The pressure sender ports will not leak, just use a little thread tape and do them up fairly tight (tighter than a filter), they are tapered threads and will pull down to a good seal.
For the main thread assemble as Mick said and tighten like a filter....still pretty tight. These things are a bastard if they start leaking.
BTW I guess you've already decided what to install....but I'd always relocate the filter at the same time to make oil changes easier.
I changed the filter and oil at the same time .
one question though , my k&n filter bought is quite smaller than what was installed, I have installed it and no issue but does this look small to you .
does oil filter restrict and reduce pressure ?
since I have changed the oil, the pressure has dropped slightly on the dashboard gauge ( the needle below rev ) from 4-4.5 to around 3.3-4
I guess this could be due to me changing the oil to 5w-40 and before it may have been 10w-60 ?
re filter , i bought it from a tuner in the uk and presume they would not sell dodgy stuff.
what pressure in psi should you read on the gauge ? I have installed evo gauge and soon will have the pressure shown in psi which at the moment i am relying on the gauge in the dashboard.
I will k&n to find out its rating for the filter .
pretty dirty
spoke to the sales guy and he said most likely mine was fitted with a wrong filter which was bigger from r33.
is this possible ?
he assured me the one I have is the correct one ?
even hks one seems small
Edited by stranger12
