Because you get to a point where you split the block in 1/2 horizontally.
Was at Sydney dragway when Maatouks VL did it. Quite a sight.
Is it for everyone, no. But right at the top end of the scale, there must be a need.
Completely agree with you - there's an rb30 bottom end on ebay for $100
So want, 25kgs light isn't a big deal when talking a 1700kg car but being able to set deck height for 2630 and not having to use adaptor for 4WD means heaps :)
isn't Bullet the dudes that put 1UZs in MX-5, i thought they where in QLD
Clearly these are for cars that weigh in the 1100kg range, not for street cars. It's gorgeous and it will work but I've genuinely no idea why they machined it with water galleries.
Bullet Cylinder Heads aren't the same company as the Bullet you're thinking of.
Also thats a standard RB26 alloy head casting being CNC ported, not a billet head. It's how they did mine.
also just fyi
they posted this up yesterday
11174770_963462717032437_270913565015250
It's a theoretical shame the max bore wasn't 90mm
Std. Clearance being 94mm crank, squeezing a custom 95mm would give you 3626cc, over a litre more capacity in a gtr.
Probably not a concern in its intended application
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
    • Nice shot! They look super clean. The roof rack delete on the black one is interesting. Would like to see more pictures from different angles. It's subtle but could make quite a difference to how the car looks in profile.
