I like something around 500bhp from fly which i think would be around 400 at wheel, right ? CONVERSION IS EASILY SEARCHABLE
I don't want to go forge or change cams at this stage . SEARCHABLE TO SEE WHAT STOCK ENGINE CAN DO
I have seen gt35,30,28 and number of others but not sure what is best for me . NO ONE DOES EXCEPT YOU, I SAY GT3076
everyone has a different opinion reading around . what would you get and what is the max power from the turbo at what psi ? WHOLE THREADS ON TURBO RESULTS = SEARCHABLE
I think gt30 is low mount which is good but gt35 or other are high mount and if i was to run gt 35 , I think it will be very lazy as I will be running it at a very low boost , right ? VERY SEARCHABLE TO SEE TYPICAL RESULTS FROM THIS TURBIZZLE
I think minimum mod to get to 500 bhp is :
550 or above injectors
bigger intercooler
ecu ( link 4)
turbo . PLENTY OF SEARCHABLE ON WHAT MODS NEEDED FOR POWER LEVLES - FUEL ECU ETC
and possibly manifold if it is not straight bolt on as most people say gt30 is .
am i right ?can i expect safe 500bhp from the car with the above cost and mod ? THIS ONE COULD BE DISCUSSABLE, ONCE YOU HAVE DECIDED ON A SETUP
if I was to do this in stages and buy the turbo and do no remap but run it at low boost , will it work ? ANY TURBO CAN BE RUN AT LOW/ZERO BOOST...BUT NO ONE WOULD, THEY'D WANT TO CAIN IT, HUMAN NATURE
dude I'm all in favour of helping those that need it, but those that don't help themselves I'm not so keen on. I've made some notes above to assist you in your quest. I'd advise do some more research, decide on a setup that will work for your goals and budget, then put it forward for discussion and for people to make recommendations on. Just asking for info to be broadly given to you really pisses ppl off, gets you less genuine replies, and ties up the forums on here.
Some of my questions as said was for confirmation of what was read
But cool mate no more replies will work it out.
What annoys other is thinking i am lazy and I can't be as i want to do it all or most diy and you can't fo it unless you know what you are doing
But then u need help everyone now and then which most people on this forum are brilliant at giving apart from few odd one
Welcome to the friendly skyline club, I'm sure you want to become a paying member now. This used to be a good place for help once but seems all the older crew have moved on.
You should help him . you know, so he stays.
Give a man a turbo he turbos for a day.
Teach a man to turbo he turbos for a lifetime.
Boost on brother.
This forum has the knowledge, but the same questions get asked all the time and they are the most entry level questions imaginable, if you have serious questions that cant be answered by a simple google they come and ask.
but you really need to apply building your own knowledge first by learning and yes it may not be the quick way but it is the only way to really understand what it is your trying to do...
I have mate don't know why some don't get it
So many choices wanted to get further views but of course all posts are currently joke
You already have too many choices and you want MORE opinions??? Lol. Sorry mate. Opinions are like arseholes, everyone's got one. The signal to noise isn't going to be any better if you ask the same old question again.
Honestly, do your research. Form your own opinion, and go with it. The decision will be yours, it will be based on the information available and you can justify the choice to yourself. And it will be a better decision than "some random dude on the internet said it was good" because you know what you want and you put the thought into it yourself.
I can't count how many times I've spent 5 hours trawling forums for info. It happens. When it gets a bit much, make a spreadsheet of the important factors to you. Or there's another tactic, Say you have 4 items to choose from. Pick two at random and pick the better one out of those two. Don't hesitate, just pick one. Right. Now look at the other two. Pick one. The two winners - put them together. Pick one. That's your final choice. Once you've done all the research you just need to trust your gut instinct.
we are friendly, we haven't told him to neck himself yet :)
well you see, most of the smart arse replies are actually from the older crew..
ok let's play nice kids..
OP, what power do you want? and at what RPM do you want to hit your targeted boost? and the final question.. how much money do you want to blow?
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
