So I'm currently half way through replacing a few parts on my S2 R33 Skyline, just wondering if I'm going about it all the right way/any suggestions.
This is whats already happened.
HKS Air filter.
Blitz FMIC
3" Turbo back exhaust
Full Tein coilovers
Electronic boost controller
This is whats going on at the moment.
Apexi power FC yet to be installed/tuned.
Hypergear Hiflowed RB25det turbo.
Z32 AFM.
555 Nismo sidefeed injectors.
Would I have any use in upgrading my fuel pump at this stage or will the stocko be capable?
Any insight into how much of a power increase I can expect to see if my tuner knows his stuff?
Anything else I should be considering?
Thanks, Jess.
https://www.sau.com.au/forums/topic/456513-any-feedback-would-be-appreciated/
The limit is clearly going to be whichever is the lesser of the capacity of the 555cc injectors (which is less than 600 engine HP) or the capacity of the turbo. Depends on which highflow it is, but probably more like <550 engine HP on that.
And hell yes. Do the fuel pump.
I agree with getting a new pump and coils. What milage is on the motor???? I once did almost the same thing but i went with HKS 3071proS turbo kit. It was still side (low) mount and ran great. Thats where the new clutch came in handy as well. I wouldn't do another HKS turbo again due to price. But a gt30 is wonderful at that setup. Providing the engine is in good health. Good luck intrested to see how it goes:D
Edited by MJTru
Yeah the hypergear highflow service has great reviews and I wont have to change any piping which won me over. Quite healthy motor roughly 140k, 160psi across all cylinders and no coolant or oil usage. Not sure what coil packs are actually in at the moment I don't think they are factory I'll post some pictures tomorrow. Thank you everyone for the feedback!
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
