Hi all
I'm wanting some expertise advice on what size exhaust I should be running for the expected power output of my fresh engine
Car is R33 GTR
Forged RB26
Ported head
HKS 272 deg cams
2860-5 turbos
Walbro 460 intank pump
1250cc injectors
Power FC
Xforce dumps
Into 2.5 front pipe that goes to 3 inch
Into 3.5 inch decat
Then 3.5 inch tomei Ti expreme titanium catback system
Hoping for around 600hp at the treads.
Would this exhaust system flow enough ?
On another note
I hate the sound of my exhaust while moving. Sounds great on idle but the moment the foot goes down it sound like a dirty Na VL with no exhaust. Will adding a high flow cat help ?
Thanks in advance
https://www.sau.com.au/forums/topic/456600-what-exhaust-size-for-what-power/
Only thing i will say is lose the X force dumps, these are a direct copy of the HKS ones are they are only an improvment over stock R32 dump pipes, get some thing with 3" outlets and then a front pipe with 3" inlets and 3.5" outlet to match the decat
its your mufflers and resonators that change/reduce the sound mostly. Though for sure a cat convertor will also help certain types of sounds too.
Sounds like your issue is more around the muffler and resonator side of things though.
With front being stainless or to small ?
as Xklaba said
If you plan on staying with low mount twins go out and get a good exhaust. CES do a good dump and from there go a good cat and muffler and 4". Do it once and do it right.
This, i have both types of CES dump pipes, factory type on my R32 with matching CES front pipe and comp series dumps on my R34 with custom twin 3" into single 4"
CES have the best split type dump pipes on the market and IMO the comp series are better then bellmouth type pump pipes
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
