JustCar told me that Capital Smart claims they can get my car done in 3-4 days. New replacement bumper. Lel....good luck mate, you can't get parts for these cars in Australia.
"It's not an import on our system" and proceeds to argue with me for 3 mins that my car is in fact not an import and they would know better.
Righto....
Righto....
Maybe he is in a call centre in Japan ;)
DUE TO POPULAR DEMAND NISMO WILL REALEASE 100 MORE RIMS LMGT4 "Forged" with Engrave logo and now includes 18x10.5+15 !!!
Nismo can receive Orders from 10/June to 29/July so be quick !!
We ship from September 2016 world wide to your door !!
LIMITED LMGT4 SPECS BELOW ONLY:
4030S-RSR26-BK
17 X 9.0 +22
5x114.3
4030S-RSR27-BK
18 X 9.0 +22
5x114.3
4030S-RSR46-BK
18 X 9.5 +12
5x114.3
4030S-RSR47-BK " New Size "
18 X 10.5 +15
5x114.3
Omori Factory Spec with Machining Logo
Color Gloss Black only
High rigidity rim 30% stronger than normal rims
Includes Black Valve and the Black Center Cap
Please email us for pricing and inquiries
[email protected]
4030S-RSR26-BK
17 X 9.0 +22
5x114.3
That's a solid reason to get a sileighty!
  • Like 2
I've don't have a gtr yet but I've email them already as im thinking if i get a set stack 2 together n 2 next to each other and put a glass top bingo coffee table in theater room and this coffee table would never get old or lose value hehe [emoji12] [emoji38]
But Wow 10.5 are going for $4400 pickup one expensive coffee table [emoji52]
Edited by pol1on1
  • Like 2
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
