12 minutes ago, colin.ssc said:
Why do you want to use genuine pads and disc? Just wondering
But also this.
Surely Project Mu or someone similar does a good set up for cheaper.
2 minutes ago, ElleAli76 said:
They want $1900 for disc and $600 pad? What do you think about the price ? If it's cheap then yea I'll get them to do it.
Wouldn't have a clue for a 35.
Someone as experienced as Galvsport with 35s I probably wouldn't even question TBH, I'd take their opinion and run with it.
Let me ask around with Nissan's
Thanks Hank and I'll be there at Galvsport by 3 to pick up the car :(
I'd try amayama, might be cheaper. Not very sure with gtr 35 parts in Australia but I'd imagine it's stupid expensive. Aftermarket probably be pretty good and price wise as well no?
Cheers Colin I'll do that too :(
I've been doing a lot of reading, and I've spoken to a couple mechanics and I don't think my tyres are a problem, I still want to change them due to age.
A lot of people, and my own research are telling me my HICAS might be playing up. I'm still researching HICAS, but it does make sense, if I were turning and my HICAS isn't aligned properly, it could have caused my rear to swing out...
Given this car has had multiple suspension changes and who knows what past, That could be right but i'm no expert.
I was just onFacebook and someone ask where in perth is the best place to get hicas looked at the response was get a delete kit or get Mark from C-red to look at it hope this helps or did you something already?
  • Like 1
