Morning all.
Elle, have cash on you over there. not many places had eftpos we found. The 7/11s have atms there and have real yummy cakes/food/drinks
I thought Japan is more advance in technology with eftpos / paywave machine but not [emoji28] ok Corey , I'll
Make sure I bring enough cash over there and prob use my cash passport debit card at the biggest store. Any idea how much is to hire snow gear over there ? And I bet place like Hakuba prob won't have any eftpos machine ?
Oh hang on there , can i take Cash out from My Cash Passport ? I can Start reload / top up more money if I can take the monies? Do they charge bank fees?
ATMs at conventicle store don't charge fees. Some banks might but there are so many convenience stores you shouldn't need to visit banks
Just keep cash on you, when you get low grab more from convenience store ATMs. I'd keep a bit on me at first until you get more familiar with everything
[emoji108]? cool [emoji41] Thank You Trev [emoji3] I hope we won't take long to get familiar with places [emoji3] I'll remind Dave to bring or get a map from
The hotel [emoji41]
Awesome ! Convenient store it's then [emoji41] 7/11 [emoji7]
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
