18 minutes ago, Manne said:
More passenger side than drivers? Are the new seals definatly seated ok? Shouldnt have that much oil underneath it unless uv got leaks else where? Sump? Turbo feed or drain?
I've done the sump, power steering and rocker cover seals.  That's less than it was leaking.
26 minutes ago, TiTAN said:
Checked around the front and rear crank seals?
Did you use some silicone gasket around the half moons for the cam covers?
No, I didn't use any gasket sealant as I've always been told not to when it's new gaskets. But I've checked and theres definitely no oil coming out of that.
12 hours ago, t_revz said:
just found out my sister has a new boyfriend
and he has a skyline...my wife thinks its a 33...so he must be ok :)
Sounds like she has poor taste  :down: :19_kissing:
  • Like 1
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
