Also got a photo of each spark plug
My opinion is plug photos are irrelevant except for checking last RPM.
ie- your plugs look richer on 3+4 but that could be just at idle.
I've pulled plugs after idling,cruising and on the highway turning engine off at 6k WOT and they look very different.
What plugs did you fit afterwards? Coppers or iridium?
Nah just did the comp n plug check
Yeah i do let it run a bit before i park up slow drive up the hill n cool down probably a good 2mins worth
Thay r PFR6A11 Laser Platinum Plug
Maybe 3, 4 could do a change coz of platinum worn a bit on edge but there not much KM on it.
Don't waste money on platinums.
Throw em in the bin
Sub 400hp I'd say bcpr6es coppers
Above 400 run 7's
Went to the city stage of the rally today. Way more skylines running in the mornings classic car section. Had some 32 33 34 gt-r and gt-st's Heaps better than the Malaga and Whiteman park stages. 5 hrs in very mild sun and strong wind. Curse of the ranga, unbelievably got burnt.
know them feels...
thinking of the sun gets me burnt
  • Like 1
On 8/12/2017 at 0:48 PM, pol1on1 said:
Yer i used deconjestion spray that solves bit of it but xray shows that i had a defomed canal that worked as a 1 way valve basically not allowing suction to top sinus (above eye) when landing which made alot of pain the worse I've is numb jaw striking pain down neck and numb collarbone with eye feeling like exploding that was every second swing landing for me.@manne I've read you have some similar issues
Yeah dude, Three weeks and i'm feeling much better but there is still a little bit of pressure around the nose/eyes that flares up from time to time.
I'm currently using a Sinus cleaner thing, it's a bottle with a thing you stuck up your nose and squeeze, and it flushes them all out.
Agree with you though, the Pain is UNREAL, I was knocked out for a good week, sleeping 20 hours a day, and then somehow, my chest became all messed up too.
Steroids, Sprays, Antibiotics and 3 and a half weeks, but i'm still not better.
know them feels...
Panicked when we got to Toodyay. Jack was like there is smoke coming out from under the bonnet. Wtf. Bonnet was a bit hot with no blanket underneath it was steaming the rain over the turbo off the top of the bonnet. Was just running up the hills in 5th and loading it up on the way there with the boost controller off. Used 4th for the hills on the way home at 14psi no probs. Different animal to the 4,9 5.8 5.0 and 5.4 lesson learned. Bugger all torque at low revs. think I will get rid of the 200cell catco oval and go to the venom 100cell with the 5" substrate. Tuning is beyond my nuts and bolts ability. Any thoughts? We ran sweet to and from Albany and did 1000kms pushing it hard. The original 100 cell metal cat copped a massive smash over a trainline bump at full speed the substrate came loose and flew into the exhaust melted and killed it and we popped a intercooler hose because it blocked the exhaust.(the weekest link) have swaged pressure tested and redone all the tubes and hoses with a intercooler flush. Would I need to retune between replacing the cats? Any advise would be appreciated. Thanks.
I will come Eli!
know them feels...
I will come Eli!
Don't get me wrong she's running and pulling hard at 18psi still. All temps and pressures are normal. Just seems to have lost a bit at say 6000 to 7000 under full load? Trevs? Kizza?
Hows weekend for Everyone ? Next week Saturday - Any idea where we going to meet up before head Down to barbagello ? Cruisinnnnnn All
Together from joondalup ?
Whos going ?
Yeah 84 and I will be there, my mate wants to come with so I'm gonna be in the Prado
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
