Yeah
Wow. Your Magna was poxy
Nissan alternator is internal reg
Totally. Battery light on. Changed the regulator, twin brush and spring arrangement. Perfect. 2 weeks later battery light on. Fractured the long brush at the housing you could see a crack just above where it fractured, demanded a new one, perfect till we sold it. Slowest car we've ever owned. Got us through new house and 2 kids born. Traded it for $1500 on a 5ltr Fairmont ghia. I loved the Fairmont. Spun off the line and into 2nd. Great little engine. Long gears. 70 in 1st 135 in 2nd. 180 in 3rd. Soft suspension. 10.5 ltrs per hundred on a trip. 1950 rpm at 115kph. Full leather and wood grain. Felt great when driving it then when you got out it still looked like a horrid au. Only mods were twin system cai and chip tune. Solid drive train. Slight touch of brake and throttle for effortless auto skids. She was a bit slow but a beautiful cruiser:-) Windsor power
47 minutes ago, Beyond Blue R33 said:
Yeah
Sounds like u were old befor u became old.... ???
  • Like 3
I drove a friends magna wagon around for a while (modified skyline reliability yo), 97 (I think) 3.0L v6 manual. Could do a fwd single legger if you revved it up and dumped the clutch but was pretty gutless for the most part, but it took everything that was thrown at it and kept on going with just the usual minor servicing.
I would rather douse my genitals in hot sauce before dragging them through broken glass and razor blades, than drive a magna
Actually, I might do that anyway
results to be posted
  • Like 2
Would you rather, driva a magna or dip ur balls in acid?
2 hours ago, Beyond Blue R33 said:
Man they have put some hours into the beast. You must be getting itchy to drive it? Manual conversion next?
for sure man, I hope he's keen to finish it cos i'm sure as keen to have it back! Manual was on the cards till this happened but yeah still on the radar just maybe not till next year now.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
