great place to teach a noob about oversteer, not that I would endorse such loutish behaviour :blush:
I’m gonna do some scouting on my next trip out near Collie and Harvey, gonna find a spot no gheyundais will be!!
On 29/01/2018 at 4:56 AM, hattori hanzo said:
Just whoop ass Wednesday mate,
I don't live in Australia, however I am back for a few weeks shortly so wanted to give it a nudge on radials.
Have had josh at Galvsport doing some testing while i am OS.
So plan is to do a pass on the AD08s to match Josh's time
Racewars
then bolt radials on to see how we go.
Result from Josh's testing below
https://www.youtube.com/watch?v=4FWvx1LB5Bs
Nice! What combo is in the car?
  • Like 1
Google “bobs hill”
That entire area will keep you busy all day in 4L
Trying to plan a shake down 2 night stay thinking Collie end of March and take the pups got any hidden spots I should know about?
Near Harvey at bobs hill. Little creek to camp next to.
Scenic drive in collie has plenty of little spots.
Stockton in collie is ok but can be busy and dogs drinking the water might get crook. Sometimes it’s not quite right.
Few spots halfway down Harvey quindanning rd near water are good
  • Like 1
I didn’t tempt bobs Hill on my dirt bike it’s nasty af!
Hi all drained as F baby keeps me busy going to work is like a holiday. Almost no sau or facebook but managed to find this 24/02/18 shannos meet from 7pm
Yep kebabs and cars is a massive event, we have a cruise this weekend.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
