Hold on tight Corey, its going to be a wild ride
on the upside, it only lasts for the next 18-20 years.....
Had one of the loinspawn join us for dinner last night, and the best bit?
she went home afterwards
If anyone needs me, I will be pantsless and farting on my couch :banana:
  • Like 1
You pantsless on the couch is probably what drove them away
Let’s be honest, it’s not something you started doing recently :)
I have started storing Dad jokes. Its gone be fun
guilty as charged :blush:
in our house, dad jokes have to be lewd and hard to understand
example
2 nuns sharing a bath
1st nun says "wheres the soap"
2nd nun says "it certainly does"
  • Like 1
morning everyone been a while since replied on here so just a quick hello yep still around am always here lurking in background, anyway i guess more aimed at @t_revz and @Beyond Blue R33 my water pump is showing signs of giving up and a few seals also beginning to leak so its at 170k will be doing the 200k service early, now as WE ALL ;) know the turbo seals will go so that will need a highflow service done shall i just go the ATR43SS2 OR ATR45 or just go highflow? Also as i am still very broken have 2 pay to get service done which gunna be expensive :( . Anyway cheers all
I’ll do it if you can wait til after my holiday. End of July. Water pump, cam seals tensioners and timing belt etc
Don’t need to touch turbo yet. Unless you really want but if your not rolling in cash then do it later.
P.s. if your water pump is leaking it could let you down when you least expect it. If it leaks out and you go for a drive it will get hot before you even notice.
Is it leaking coolant? Or noisy? Or what?
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
