Dale.
I'm doing an order from Troy's Meats if you want anything - https://www.facebook.com/troysmeats/posts/706363436366223
Getting Hank some lambs necks, come in packs of 2 and they're full necks, not the little cut up rosettes, so awesome to keep the doggo interested for a while ("soft" bone as well).
Cant see FB at work, so link is no good, but you reckon you could grab an extra 2 packs of the necks for me? I will get Blossom's opinion of the secret butcher first before I go buck wild. OK if I fix you up for them on Sunday?
I had Cape Grim for the first time a few weeks ago, and would def recommend. Pretty sure he stocks the grass fed stuff
On ‎7‎/‎17‎/‎2018 at 8:37 PM, pol1on1 said:
Yer oil dipstick popped out too much pressure in crankcase.
Not sure to why i had so much pressure to do that. But to fix the problem and do happy track dayz i think i need a catch can, larger sump, baffle kit for sump n cam cover, oil restrictor Maybe even a oil accumulator on top.
Then it might hit the track again but for now ill keep it straight drag pass.
Did loose about 4ltrs of oil from 6 hardly touching the dipstick that how known something went wrong as i was going up the shecane at 6k to 8k rpm i look down n noticed oil pressure at 2kgcm2..... at that point my car seat had me by the balls.
No knocking but at idle in gear lift the clutch put load on engine makes a small squeaking sound n crank pully has very slight movement . So thrust bearing has worn too much. :(
Not fun.  The root cause of it all is blowby.  Around Wanneroo RB's should be fine.  Before you chuck any bandaids on it check the compression.  Also as has been said check the remaining oil for go fast glitter.
  • Like 1
Yup
So, I learned a thing today
Turns out there is a sentence terminator called an Interobang, and its actually recognized by Websters as a valid way to end a sentence, and is usually to infer either a rhetorical question, or a question used as a statement.
Actual composition is a combination of the question mark and the exclamation mark.
Unicode for it is U+203D for any fellow word nuts that want to give it a crack
  • Like 1
11 minutes ago, Stinky Rooster said:
Yup
Cool
  • Like 1
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
