Yeah i was only thinking of the stroker kit only.
Isn't the height change the only problem was thinking that hypertune now make a low profile rocker covers.
All your intake and exhaust needs to be modified for the extra height, intake may interfere with the brake booster etc
  • Like 1
ok so new turbo has arrived, looking at injectors and fuel pump on the injectors side of things any one know what i can get in bosch brand that will drop in to factory fuel rail? or should i replace that also? (for a rb25 neo) so many different infos on the interwebs now so confused
  • Like 2
I used these folk.
http://www.nzefi.com/products/fuel-system/fuel-system-injectors/vehicle-specific-injector-kits/
  • Like 1
yeah i saw those in my search as well as the kit from kudosmotorsport but was hoping someone would know the specifics (part number or anything) so can see if can get some better pricing? but thank you
3.0/3.2/3.4 would be the way to go for reliable power but its also the quickest was to empty ur life savings. Depends what how much hp u want...
Happy Belated birthday ! Hope you get spoilt rotten from the love one xx [emoji8]
P/s - I need more tv’s hahahaha my remotes suddenly just stop working
  • Thanks 1
Did you try replacing the batteries?
Hey all, we should do Nando’s soon!!
  • Like 2
Martin I did [emoji849] its an old tele and I bought the universal remote from JB hi Fi and it didnt work Either [emoji849]
Anyway Nandos is Perfect ! Lets do on Saturday ? Zod & Peter Keen x
  • Like 1
On 8/8/2018 at 5:32 PM, t_revz said:
Hey big daddy
How the screaming and shitty nappies going?
Oh and what about the baby?
She's going good, bub is going good also. We have figured out, that if we can settle her before 10ish she will sleep the night. Is already pretty good with workshop noises, makes noises and is super flirty with smiles and big eyes
On ‎14‎/‎08‎/‎2018 at 7:45 AM, turboedsloth said:
....... is super flirty with smiles and big eyes
that's freaking adorable
she is just like her Dad already!!!
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
