Update: Turns out there some some mechanical thing in the fuel pump which tells it to be quiet when driving at low RPM, that was causing the fuse to blow, so Mark and the boys deleted it, seeing as it's not necessary at all.
I don't want to jinx it, but...the car runs.
  • Like 3
19 minutes ago, t_revz said:
Soon you’ll have grandkids to take
lol nope
one is way too narcissi and the other works in daycare (the greatest prophylaxis ever invented for pregnancy)
sup.
Warning - don't let Hank into your lives, or this might happen.
Meet mah new dawg, Cletus. Ex racing doggo with a sad and dark history. That look says "I have seen some shit...."
and by the sounds of it, he def has.
  • Like 1
Yeah, my main fear is him doing a runner. I don't reckon my bike would even keep up with him when he drops the hammer.
Going by the fact that his only real concern seems to be having at least 1 human in sight at all times is reassuring. Its got me stuffed how anyone could just keep these things in a cage and try to provoke their prey instincts.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
