Update: Turns out there some some mechanical thing in the fuel pump which tells it to be quiet when driving at low RPM, that was causing the fuse to blow, so Mark and the boys deleted it, seeing as it's not necessary at all.
I don't want to jinx it, but...the car runs.
  • Like 3
19 minutes ago, t_revz said:
Soon you’ll have grandkids to take
lol nope
one is way too narcissi and the other works in daycare (the greatest prophylaxis ever invented for pregnancy)
sup.
Warning - don't let Hank into your lives, or this might happen.
Meet mah new dawg, Cletus. Ex racing doggo with a sad and dark history. That look says "I have seen some shit...."
and by the sounds of it, he def has.
  • Like 1
Yeah, my main fear is him doing a runner. I don't reckon my bike would even keep up with him when he drops the hammer.
Going by the fact that his only real concern seems to be having at least 1 human in sight at all times is reassuring. Its got me stuffed how anyone could just keep these things in a cage and try to provoke their prey instincts.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
