Hey ladies. I’m still keen if others are. Not sure if family will be able to come yet. If it’s easier should we just meet at carousel or similar and grab coffee/lunch and chew the fat for a bit?
Sounds good but not carousel it’s insane now what about the usual Nando’s? Vic park
12 hours ago, turboedsloth said:
Will see if i can get away. Have 2 big builds to get out before christmas thats all
You could always show up and sit elsewhere for a bit ?
as much as I would love a BBQ I am busier than a one legged man in an area kicking competition ATM. Changing contracts (and possibly whole work environment)  is keeping me flat out.
Sorry guise, I was called into work for Thursday night earlier in the week and now I’ve been called again for Friday night so I’m out for Saturday. Doesn’t seem to be much interest but hopefully we can do something January or something after the silly season
  • Like 1
Ok agree let’s reschedule to jan
Pft
softies.
Softies everywhere
But Yeah, Jan would be betterer for me too
"The mind numbing servility of a 50 hr week and we expect no reward, except for this broom cupboard over our head".
