Yeah, but on a brand spanking new bike.
Finally traded in Ragnar The Yamaha, (after 6 months thinking about it) and stepped on to a shiny new one with all the mod cons like EFI and ABS, but it looks like a late 60's triumph
Plus, in true hoon theism, I made sure to get some loud pipes fitted before delivery. Pretty sure they will fail a sound test, but YOLO.
Cool..... Lauda is faster and safer. What kind of bike is it?
Yes, yes it is. Its also a LOT more fun in the tunnel than a single that sounds like a huge briggs and stratton.
Its a Royal Enfield Interceptor. Brand spanking new 650 twin designed by ex-triumph engineers.
Cool... how much was it?
Nothing wrong with a Briggs n Stratton!!
Just take an XT600 through in third gear.
Fluffy - the bike was stupidly cheap for what it is. Came to just shy of $10.3k with the fuwlly sik zorst.  Still got a couple of hundred to blow on other farkles when the genuine accessories become available in a few weeks,  needs a fairing,  crash pad for the bars and soft panniers.
Yeah I checked out some of their stuff. Looks cool. I liked the retro side car deal. [emoji848]
    • So I put it to 3bar (43.5psi) while priming. It stays at 43.5~ as I crank shakes slightly. Ive also tried dropping pressure to see if that changes anything. I replaced the fuel dampener because I was troubleshooting the system along with the stock FPR (swapping them one by one to rule them out). But i only got up to changing the dampener and it started running again. Injectors are stock second hand. I did a bench test on both my original ones and the secondhand ones. The second hand injectors I have in the car now spray slightly stronger than my original injectors.
    • I knew Andy from about then, it did some cool stuff. By 2005/2006 era, he also implemented closed loop ignition timing tuning. In 2004 it was pretty cool, being with him when he was doing automated fast self learning tuning!
    • Im No tuner but…. im running a 25det with north of 600wkw at 9000rpm e85 and water meth. G40 1150 on 32psi. Having a real built head will flow a crap ton more power but you being stuck at 7600 won’t be helping at all, throw all the boost you can and nothing will happen. Solid lifter and 9000rpm is the only way,  I have built my motor 3 times, not from engine failure but more along the lines of my failures in not understanding engine parts better, basic phrase to help, “block hold power”  “head make power”
    • What's the fuel pressure while the car is cranking? Curious, why did you replace the fuel damper? What injectors are you using, are they brand new?
    • I think it's terrible value, it should be half that price IMO. And I'm known as someone who will unironically suggest the GTIII-SS on the RB26 if you have very specific requirements. The GCG RB25DET "hybrid turbo" is 1/3rd the cost of this GTIII-RS kit and sounds like it should fit with zero modifications. Talk to Hypergear as well, maybe they can do something that fits your requirements.
