HI There,
I have oiling issue on my RB3025 néo engine. I HAVE READ NUMBERS OF TOPICS ABOUT THAT... BUT... found no solution.
A complete drawing will be the best to explain my sittuation.
Engine is pulling hard, I don't think there is too much blow-by...
I really hope a solution to fix that and raise up my boost !
See attached file !
Cheers from France ;)
First, ensure that the breathers from the rocker covers to the catch can are both seperate. T-ing these lines effectively halves the breathing capacity.
Secondly, introduce some vacuum into the system. Either via the pcv valve or pre-turbo but preferably both. Vacuum in the crankcase is a good thing.
Lastly, if that doesn't work, hide under some coats and hope that somehow, everything will work out.
Your plumbing looks ok but
1. are your sump breathers both above the oil level in the sump?\
and
2. is your catch can 300ml? It needs to be 2L (2000ml)
also what oil pump and do you have any restrictors in the oil feeds?
As has been said get a bigger catch can because 300ml is way too small
Also needs one way check valve on the drain back from catch can so oil doesn't pump out of it. As r32-25t said it needs the sump breather to the can well above oil surge level or you are just pumping oil up the breather.
And I just saw you have the rear head breather teed to the turbo oil drain. That's not a good idea because you could be causing oil to back up into the turbo drain.
Edited by Dobz
  • Like 1
how are people getting a hole above the oil surge line on stock sump? I was looking at my block today and couldn't really find a good place to drill a hole in the side of it without it coming close to the structure of the main caps which I don't really want to drill into the block anyway...
This
Well its easy with an RB26 sump but I imagine with a steel sump you could have an elbow facing up til its well clear of the oil level so long as it doesn't get in the way of the crank etc.
  • Like 1
^ Im liking the way youre thinking!
In regards to dobs post he said that you need a one way check valve from the drain of the catch can to the sump to stop oil from flowing out the can, im a little confuzed as to how crank gasses can get out then? As i thought that was the point?
Frank there is a breather hose and a drain back hose. The drain back is the lowest hose.
Some people put a check valve in one line and it works for them. I have no check valve - my theory is at full WOT pressure escapes via both hoses and I haven't found an uphill straight long enough to fill my 2L catch can so when I lift off it drains back fairly quickly via the bottom hose. But others have a check valve in one line with no problems.
  • Like 2
OK buddies! thanks a lot for your comment ! ! !
1. I must have forgot the check valve trick. Whitch seems a great solution for me !
2. Aswell as the 2 liters can !
Dobz : "I could be causing oil to back up into the turbo drain T'ing it with the rear head drain."
I thought the rear head drain was a drain. You think it is more a blow-by vent? (it shoudn't be as the bottom end is already vented on the intake side (as much as possible))
And I never saw my ball bearing turbo smoke oil (my exhaust piping is clean). And I have no other place to T the rear head drain.
Does some people here think the rear oil drain is useless?
White GTS-T : 1. I thing venting it (pcv etc...) in the engine intake is the risk of putting oil in it and knocking. Quite risky i think whith my E85 setup (high timing).
2. T'ing the 2 top lines of the cam cover minimise the amount of air venting out of the head ; then minimize the amount of gaz coming up from the cranckcase... => Better oil drain from head to cranckase then IMO. Don't you think ?
3. what does mean : "hide under some coats" (english is not my first language ;) )
Attached is a bigger picture of my sump. My holes are all above the oil level. I was just hoping that the oil wasn't comming in front of those holes when accelerating... It would cause oil to get up in the catch can. (But it is meant to be a RIPS model...)
Edited by lolo.37
My spool head drain tees in with the turbo drain. Havent had any issues yet. Checked my catch can the other day and its bone dry. I run a line from the catch can to the intake pipe and a PCV though so different setup.
Needs more rpm :P
Are you actually getting oil from the breathers?
For an N1 pump to push that much oil there's something funny going on.
I would be looking at your catch can drain, being on the intake side isn't a good idea IMO.
  • 1 month later...
OK This seem to be solved!
As you advised me :
I have put a check Valve in the oil drain. (was a 14mm on picture but replaced by a 17mm model)
I bought a 2 Liters can; (I baffled it myself just to do things perfectly right)
See attached files !
And TA DAAAA ! Done! No more oil coming out ! This is great !
But now there is a question that haunts me... How much oil can I put in my catch can and in my heads. There must be some oil stocked by those 2. It needs to get down on the boost/revs so oil can return back in the sump.
From how many seconds to the limiter do I take a risk of sucking air in the oil pump (while cornering mostly, using extended oil sump)
Anyone as ideas ofhow to check that?
Edited by lolo.37
That's what the restrictors are for - to minimize excessive oil in the head - and if you have a 2 litre catch can that's the most that can fit so if you have an extended sump (8-9 litres?)_ you are unlikelyu to empty it. As soon as you lift off the oil in the catch can should flow back pretty quickly. If you have an aftermarket ecu you should be able to log the oil pressure but I doubt you are emptying the sump now.
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
