Looking on Spool imports site I see they list a complete RB34 short engine, block, crank and pistons etc etc
Has anyone got one and what do you think of it and the build work done?
btw, for use with RB25/34 road/drag use
cheers
They used to have a video on their site of one a dyno making about 900hp but haven't seen anyone actually post one up here.
https://www.sau.com.au/forums/topic/457460-spool-34/#findComment-7550239
Cheers, from what Spool have told me that bottom end is good for 8 - 9k rpm limit
But what head would peeps recommend using between the 2.5 GTST head and the Neo head for a 3.4 conversion?
To make full use of that rev capability I have the option of using my current RB25/30 GTST s1 head with Tomie pon cams but still on hydraulic lifters. That I've been advised (and used) 7.6k as a limit and believe it shouldn't be reved higher?
Or go buy and build it with a neo head and high lift cams to make full use of the bottom ends rev range
26 head is out as none of my ancillaries are going to fit. Any other options other then convert my GTST head to solid ?
https://www.sau.com.au/forums/topic/457460-spool-34/#findComment-7550875
atm I am using a T3 bb GT35 but with a 1.06 exhaust housing. If that will now be undersized I don't know? But when it was mapped as a 3.0 it wanting to keep making power past its 7.6k rpm (safe) limit so maybe not?
As for the rev range yes it seemed odd but as they don't know 100% what I will be bolting onto it that's maybe why?
I haven't got a problem with that, more that I am happy I know a safe range ... or max when built
Yes the head needs to be right and be able to run to the bottom ends limit
https://www.sau.com.au/forums/topic/457460-spool-34/#findComment-7551093
A GT35 will have epic response on a 3.4L certainly wouldn't be testing the bottom end of the spool kit. Nor would i think it'd warrant a big $$$ head either.
I'd imagine a GT35 falling off around or probably before 7K.
Depending on what exactly your plans are for the car maybe start looking for something like a 6466?
https://www.sau.com.au/forums/topic/457460-spool-34/#findComment-7551129
As above I can only repeat what I was told by the dyno operator re it still making power all the way to its redline of 7.6kI
it would have reved on and made more if it wasn't for the hydraulic lifters
btw this is a sunday toy and for occasional drag strip use hence wanting the spec
https://www.sau.com.au/forums/topic/457460-spool-34/#findComment-7551370
Sounds like a bit of a greek salad.
Your going to the trouble of selecting a 3.4L for a drag build and then talking about limiting it with the head and turbo.
For drag, RPMs can help with the power up top, turbo needs to run up there and not be restrictive in housing.
Big lift cams and big turbo housing can get you some serious MPH but will sacrifice streetability.
The other thing is rod stroke ratio and piston speeds if your going to rev a 3.4L hard.
Get yourself a RB30, forget about stroking it and go from there.......your not in the zone for a stroker.
25/30, forged bottom end, bit of head work, right cams and turbo and your there without the stroker expense, if it blows its not so much of a money pit and cheap to rebuild/replace.
https://www.sau.com.au/forums/topic/457460-spool-34/#findComment-7551401
No I don't want to limit it with turbo or head but just thoughts on what would be the better way to go?
Maybe there isn't? If I stay with a GTST it will cost to get the head converted to solid and new cams
Or if I went neo it will cost again for cams and a head.
Both might end up about the same?
Yes I use the car up the strip but its not going to be an out and out drag engine, as I still drive it as a day to day car (when its not raining lol)
Will see what turns up anyway as neo heads aren't that easy to come by by the looks of it either
https://www.sau.com.au/forums/topic/457460-spool-34/#findComment-7551412
Neo head with a shim under conversion is on par with a 26 generally.
Gt35 does not seem big enough to warrant a 3.4
6466 is a great combo for a 3l.
You should make 500kw + (e85) never have to worry about how high your limiter is.
Save the extra from the stroker crank, put it into the head.
https://www.sau.com.au/forums/topic/457460-spool-34/#findComment-7553045
Get Rips to ship you a 3.2 engine - he may be able to find you a Neo head as well.
http://www.ripsracing.com/
  • Like 1
https://www.sau.com.au/forums/topic/457460-spool-34/#findComment-7553074
What's involved in doing the shim-under conversion on the Neo head?
https://www.sau.com.au/forums/topic/457460-spool-34/#findComment-7553145
Cheers, have decided to go for the neo head so am on the lookout for one now
As for the 3.4 motor its a done deal. Deposits made so the sooner its built and over here the sooner I can get on with it
In the mean time I have my 25/30, turbo and injectors etc etc which I can use to help finance this new build
Will see how it all pans out I guess so no doubt I'll have a few more questions lol
btw, Talking of injectors am I still likely to get away with my 740 nismo s/feed injectors, greddy copy manifold on a Neo?
Or is that impossible to say till its fully speced
Cheers
https://www.sau.com.au/forums/topic/457460-spool-34/#findComment-7553244
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
