Very interesting as I am having similar intake temp issues myself. Are you triggering this through the ECU or does it have its own controller?
On 1/8/2018 at 10:34 PM, Ben C34 said:
I have seen the videos and have owned one.
That test sort of shows  an issue that I wonder about. It's the fact that the flow of water is pulsing. So one cylinder may get more or less than another depending on where in the air stream the pulses are. From what I could tell the rate of the pulsing isn't given.
Also that video doesn't show how close the valve is, I imagine it is as close as possible.
I suppose my concern is it isn't the same as actually injecting fuel, so therefore doesn't have the same control.
Don't get me wrong, I like the idea of it, I just don't like it enough to buy another one after having parted out the car it was on years ago.
currently I am using a single nozzle pressure activated system and for all purposes it is doing the job great. Granted I don't need my car to have great part throttle boost response (drag use, straight line warrior, can't go around corners etc) so it's not the best example.
just thinking out loud. E85 injectors would be the best outcome for a properly controlled setup, if they handle it. Cmon Bosch, make me some injectors, I will buy 8.
Here is how I get around your concerns and the only real way to do this on an  inline 6cyl engine.
To save a pissing match or others getting upset its not an advertisement nor me selling anything. Just interested to help if they are keen to know some more feel free to ask. Performance specs listed here > http://www.aquamist.co.uk/forum2/vbulletin/showthread.php?t=1590&page=42
Control aspect is fully integrated on the ECU control side, engine can be run with, without, partial, or otherwise on the water injection system. I have found this is the best way to do it, its basically automated and say if something is 'wrong' on any one part of the system the knock control (to give an example) will act as a final trip to eliminate any engine damage from ever happening to an expensive engine such as pictured below.
Edited by RICE RACING
On 6/3/2018 at 8:16 PM, Bond said:
I didn't realise you would use so little.
If you want to use WM50 at the level I guess most here want? (to exceed E85 performance) a more realistic usage rate is say on 1% on load in 650km road driving you will use 15lt of fluid. The pictured motor and link I provided we have done this in one month of durability testing, extrapolate that out to 200lt a year so 100lt of Methanol if mixing by volume.
Its more fair to express the usage rate in terms of ratio to main fuel supply, everyone's going to vary obviously depending on time on load and ultimately how much the car is driven, so you can not put a nominal figure on it based on these variables. You could be mixing WM50 every week for example.
On ‎1‎/‎8‎/‎2018 at 2:21 PM, Ben C34 said:
I hope i don't upset the calm here, however i am very curious how it is possible to implement a really good water/meth injection setup.
By that i mean with ultimate control. The simple on / 0ff system being the lest control, however completely workable at full noise.
Its just that at part throttle too much spray is occurring.
The Aquamist use a high speed valve to modulate the flow, however that is just affecting pressure downstream that gets to the nozzles, so a lower pressure would be a poor distribution i would have thought?
Seeing as you need to increase pressure by 4 to double the flow, it seems the useable range of modulation is limited.
So my question is, is it possible to get a really well controlled water meth spray in all conditions, not just full noise?
Seems to me its tricky. But also doesn't really matter i suppose if spraying too much at part throttle.
That's what I thought my Stage III Snow performance system did?
I have it set up to start at 7psi and/or 30% IDC, and all in at 14psi and/or 70% IDC, so its variable between 8 to 14 psi and/or 30 to 70% IDC.
But I can set up for any values really...its up to me.
Or am I reading your question incorrectly?
BTW I use around 2 litres of 50/50 mix every 3-4000km, highway miles though, no city driving, no commuting, no boy racing, pretty much open roads only.  Going up a steep hill, some going through the gears/taking off maybe,  or overtaking uses it.
But how much is it flowing at the start? 1% or 20% of max.? I can't see how the flow can be controlled with a decent spray at low values. The aquamist high speed valve is really just dropping the supply pressure to the nozzle/s, not working like an injector does. in a way its nicer than modulating the pump flow, but i wonder how the pulses of flow through the nozzles impacts overall water meth delivery as it isn't consistent.
I am currently using a twin stage system, at least then i know at a certain point i get 500cc then at another point i get 1000cc total. Like i said i have owned and used an aquamist system and sold it. (different car now)
Using boost alone for a variable flow system to me is totally pointless, you could be at 1 or 10 psi at 3000 or 8000rpm, which would require different flow.
Using injector duty cycle is the most logical, followed by MAF voltage. But at the moment i kind of just like the idea of an "all in system", because at low loads you dont really need to run any injection do you?
i am going to play around with PWM control of my pump, and i have a flow meter (industrial one) so i can actually log flow, and maybe setup safeties based on that.
  • Like 1
yeah, not sure how much it flows right at the start, I don't have a feed curve.  But I am also conservative in my thresholds...which probably aids as a 'fudge factor'.  Would be interesting to find out what the baseline is for the SP3 kit, I am assuming it would be more like the 20% or more so than the 1%...but I don't know.  I might have a look on the SP website and see if they have anything.
The fact that the SP3 kit uses dual triggers was what sold me...IDC and boost one or the other can trigger the system.
Edit: Nothing on their website...I have sent them an email, hopefully they will reply with the goods!!!
On 6/1/2018 at 9:16 PM, JGB1600 said:
G’day guys,
Had an enquiry earlier in the week from a member who has been following this post so thought I’d share some updates.
 In one of my earlier posts, I mentioned that WMI and E85 would be a killer combo.
Top work Orlando ;)
Water is the key here, as you know there is way too much ignorance around this. 100% Methanol detonates in spectacular fashion in drag applications as does Ethanol. The Aquamist systems I have found to be great, we focus heavily on fueling quality and qty, as well as cylinder combustion stability in all operating conditions.
Keep it up mate.
Reply from Snow performance:
"We have a minimum duty cycle the controller will send out which is rated for 50 psi pump pressure ( nozzle are rated to atomize down to 40 psi ) so 1 % duty cycle is 50 psi ramping up to the 100%. while 1% duty cycle is possible because of the way the system generally kicks on i have never seen the controller read a 1% i think i have seen as low as 6% once the ramp up begins.
The amount it uses per % point will depend on nozzle size, absolute pump pressure settings and screen filter dirt level - there are a lot of factors that relate to the exact amount of fluid being injected."
I would have loved a graph showing the ramp up but SP don't seem to have one unfortunately. Their last statement is a cop out IMO, they could have done a family curve for all nozzle sizes or a single graph with formula to use for your specific setup.
  • Like 1
Well that is very interesting
 a 1000 mL at 100psi nozzle  will flow 770 mL at 50 psi which is not particularly progressive, and certainty not as progressive as people would assume.
makes a simple dual stage system look pretty good!
Edit
i it I assumed it is 100psi max and that wouldn’t be the case, so my math above is off. Will update it later
Edit
That's a pretty aggressive flow rate you are looking at...drag racing?
I use a 375 nozzle which is more than enough for how I use it and as stated before don't use that much for normal driving.  They say the SPIII kit can handle a twin nozzle dual stage setup though....I just don't need it.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
