Hey guys, I've got a r33 with an rb25det in it, following are the mods;
-splitfire coilpacks
-power fc
-FMIC
-3' turbo back exhaust
-Z32 afm
-570cc denso injectors
-walbro 255 fuel pump
-Hypergear ATR43SS-2 turbo waiting to be installed
-gizmo EBC
And probably a few more
Question is, im chasing about 270-280 with the new turbo and tune, however my tuner was saying the injectors might not be big enough and should upgrade a 460 fuel pump to mitigate the issue. Talked to a few other people and they said don't bother just upgrade injectors.
What does everyone reckon ? Upgrade fuel pump and keep and injectors and scrape by or just go bigger injectors, and if so, what size and brand ?
Thanks in advance for any help
https://www.sau.com.au/forums/topic/457915-injector-size/
The injectors are large enough. They will support over 300 rwkW. That is getting a bit close to the margin, so if you want some comfort then sure, upgrade. Your best bet would be Bosch EV14 based ones. Probably 1000cc would be the best choice. They'll be much better injectors than those nasty old school Denso ones anyway, so don't worry about them being too big.
The fuel pump will probably be fine. Too big a fuel pump causes unnecessary fuel heating - so it's not a free choice anyway.
https://www.sau.com.au/forums/topic/457915-injector-size/#findComment-7560423
Well this has just made the decision that much harder, tuner and mechanics saying go bigger. But thanks for the feed back guys
Well mine made 314AWKW with 550s and had plenty of room for more. Name the workshop that says you won't make 300 on 570's !! I reckon they will do 350 at least if not more.
However if you have money to burn stick some ID2000s in and you will not have to change them for a while.
https://www.sau.com.au/forums/topic/457915-injector-size/#findComment-7560643
570cc injectors at 80% duty cycle 1 bar of boost will make 324kw - ish on 98 , I recommend not going over 80% duty cycle, and more fuel is better than not enough. Your 255 fuel pump will be fine aswell. I wouldn't change anything.
Edited by skyline32sup
https://www.sau.com.au/forums/topic/457915-injector-size/#findComment-7562464
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
