clutch ready to go back in
new nismo engine mount
also a brand new slave cylinder and clutch line to get rid of the other shit
and the box fitted back into the car, after fitting the line I’m not happy with it as it’s far to long and I’m going to make better one using speed flow
  • Like 2
dump pipe is back on and fitted to the exhaust as well
tightened up the balancer bolt and fitted the mandrel and belt for the oil pump.
also fitted the a/c lines to the a/c pump and with the brackets pushing the pump further out from the block gives so much more room for the turbo drain to snake through
  • Like 2
I also forgot to mention how easy the top starter motor bolt is without all that shit under the inlet manifold, you literally just reach in from the top and put it straight in by hand
  • Like 1
Haha not even close, i Ordered a radiator and waited like 4 months for it to be made, then when it arrived it was the wrong one and now the new one won’t be made till the 28th
LOL...
Hmmm... does it start with H and end with e?
  • 1 month later...
made up the heater hoses out of bmrs lines
got the correct radiator and slipped it in only for the fan to hit on the mandrel for the oil pump. Out it came and will be for sale while I go back to the drawing board
  • 3 weeks later...
Haven’t updated this for a while, I went on holidays and then had the flu 3 times in 2 months and when I have been well it’s been lots of little jobs that haven’t been finished for one reason or another.
First I changed the fuel return line from -6 to -8
Replaced the short series filter to a long one4D7C3390-05F4-402B-BAC4-7804E0CC8B69.thumb.jpeg.4d3e59ead324348ebcc06f3ea4b45d4c.jpeg
then I grab a set of these brackets and took the option for the hicas line holders as well
installed them and used the hicas line holders to hold the 2 -6 lines for the power steering
  • Like 1
I changed the fuel rain from being twin -6 feed and single -6 return to single -8 in and out
mounted the filter and plumbed them together
also am moving the flex sensor closer to the regulator and grabbed turbosmarts new -8 reg. Still some fittings and etc to get them in there, also fitted a pressure sensor for more safety
  • Like 1
Also means you can setup differential fuel pressure on the Kebabtech 😎
So regardless of slightly fluctuations on fuel pressure you'll inject the right amount.
Notice my logs before had rock solid AFRs? 😊
  • Like 2
Got most of the oil system plumbed up
got the oil filter into place, I hate where it is but it was the only place I could find where it wasn’t in the way of anything
Then plumbed the oil cooler In, BMRS fitting and hoses make this stuff so easy
and then the 2 -16 hoses run the length of the car into the boot, need to build a bracket to mount the tank and then the oil system will be done
  • Like 1
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
