clutch ready to go back in
new nismo engine mount
also a brand new slave cylinder and clutch line to get rid of the other shit
and the box fitted back into the car, after fitting the line I’m not happy with it as it’s far to long and I’m going to make better one using speed flow
  • Like 2
dump pipe is back on and fitted to the exhaust as well
tightened up the balancer bolt and fitted the mandrel and belt for the oil pump.
also fitted the a/c lines to the a/c pump and with the brackets pushing the pump further out from the block gives so much more room for the turbo drain to snake through
  • Like 2
I also forgot to mention how easy the top starter motor bolt is without all that shit under the inlet manifold, you literally just reach in from the top and put it straight in by hand
  • Like 1
Haha not even close, i Ordered a radiator and waited like 4 months for it to be made, then when it arrived it was the wrong one and now the new one won’t be made till the 28th
LOL...
Hmmm... does it start with H and end with e?
  • 1 month later...
made up the heater hoses out of bmrs lines
got the correct radiator and slipped it in only for the fan to hit on the mandrel for the oil pump. Out it came and will be for sale while I go back to the drawing board
  • 3 weeks later...
Haven’t updated this for a while, I went on holidays and then had the flu 3 times in 2 months and when I have been well it’s been lots of little jobs that haven’t been finished for one reason or another.
First I changed the fuel return line from -6 to -8
Replaced the short series filter to a long one4D7C3390-05F4-402B-BAC4-7804E0CC8B69.thumb.jpeg.4d3e59ead324348ebcc06f3ea4b45d4c.jpeg
then I grab a set of these brackets and took the option for the hicas line holders as well
installed them and used the hicas line holders to hold the 2 -6 lines for the power steering
  • Like 1
I changed the fuel rain from being twin -6 feed and single -6 return to single -8 in and out
mounted the filter and plumbed them together
also am moving the flex sensor closer to the regulator and grabbed turbosmarts new -8 reg. Still some fittings and etc to get them in there, also fitted a pressure sensor for more safety
  • Like 1
Also means you can setup differential fuel pressure on the Kebabtech 😎
So regardless of slightly fluctuations on fuel pressure you'll inject the right amount.
Notice my logs before had rock solid AFRs? 😊
  • Like 2
Got most of the oil system plumbed up
got the oil filter into place, I hate where it is but it was the only place I could find where it wasn’t in the way of anything
Then plumbed the oil cooler In, BMRS fitting and hoses make this stuff so easy
and then the 2 -16 hoses run the length of the car into the boot, need to build a bracket to mount the tank and then the oil system will be done
  • Like 1
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
