Hey Guys,
Been looking at R34 GT-R's lately.
Saw this one for sale for a while now,
http://www.carsales.com.au/private/details/Nissan-Skyline-1999/SSE-AD-2284409/?Cr=2
Anyone know anything about it ?
It's done extensive work to it and priced pretty low considering and its a V-Spec aswell.
Thanks
https://www.sau.com.au/forums/topic/458178-r34-gt-r-australian-market/
Why an engine rebuild within 15,600Km?
Bet you it spun a bearing.
Now the scary thing is who built the engine and if it did spin a bearing did they machine or use a new crank.
Hahaha i think that he's saying that it was "CHASSIS HAS DONE 75,000 Km, ENGINE HAS DONE 15,600 Km"
So the KM represents the KM since the engine rebuild.
Ah. So The original engine lasted 60,000. ?
I'm going nuts over this same issue :wacko: . I miss my GTT too much so I've been looking at a 34GTR vpsec for the last few months.
Last option is to import one.. But as you guys can imagine I'm gettin a lot of resistance from family and friends saying dont spend so much on an old car.
Also I heard rumours about govt dropping import duties since the aus car manufacturers are shutting down their plants.
Will the 34GTRs retain their value? How much should I be spending on a clean one? I'm only lookin at V-spec and above. Preferably blue. :woot:
What I have noticed,
34's have started to drop in price. Average price of one that looks nice $40k.
And I dont know what is going on with the market but 33's and 32's are now going up.
I dont know if people are getting close to the asking price for their cars but if the whole market is demanding xxx then they will receive xxx.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
