hey I just checked nissan fast for the part numbers and they do seem different for a s1 and s2 but I remember purchasing a s2 bonnet and the mat from my s1 fit perfectly. here are the numbers anyway
S1: 65840-15U00
S2: 65840- 26U00
Hang in there Hadouken, I'm just waiting on price landed in Australia.........I've contacted the business and am waiting on a price.
Once I get this I will move from an EOI to an actual group buy with firm committments and deposits etc.
tridentt150v - GTst S2, I might get two anyway, put one away for ron??
hadouken - GTR R33
89CAL - Gtst S2 Get another one so x 2
Robzilla - GTR - R32
Ty1 - Gtst S1
kingtube69 - Gtst S2
kila32 - GTR R34
R33 gtrv-spec - GTR R33
When I do order I have asked for shipping and not air frieght to reduce the cost......it will mean a delay in supply but given that the mat doesn't stop you driving your car I think we can all live with that.
I also need to talk to the business about how we go about it - it could be that they will be happy for me to collect the numbers etc and they assume control of the business side - which would be fine as well, I'm def not in it for $$$ only to pay for and get my mat and [corny I know] help others do the same.
Not joking at all tridentt150v
The carbon bonnet also has some sort of matt, just a small one above the turbos.
See attached pic
<script src="safari-extension://com.ebay.safari.myebaymanager-QYHMMGCMJR/74e632ee/background/helpers/prefilterHelper.js" type="text/javascript"> </script>
i'd be a 100% in on one of these if by any chance you can get one??
Ok not much of an update, Import Monster are still yet to get back to me with a price. They say that the Gtst ones are fine [but didn't offer any more info than that] but they are still waiting on ones for the GTR's.
SCRMER - what model?....R34 GTR?
2000/01 - Vspec II - It's the small mat that sits next to the naca duct on the CF bonnet. The one in the pic that StretchGSK posted
I honestly have no idea, but how much can they charge for a bath mat??? :woot: At least yours should be easy to post out, not like our two man tents.
I have asked and will inform when I get the answer, but all I can do for now!!!
Coincidence or what>>>I thought I'd better update and there was your msg.
Was away last week with work [and in the outback] so I couldn't follow up. I asked the supplier yesterday but as yet haven't received a reply.
Hopefully some time today??? as soon as they reply I'll be on here.
I'm just as keen as you guys.....but I don't want to badger the supplier either so am treading that fine line between keen buyer and serial pest...........lol.
Hot off the press.........reply from Import Monster just now!!!
"Nissan's been closed due to O-Bon week in Japan for the past week or so, so I'm expecting to hear back from them any day now.
R33 Gts25t S1: 65840-15U00
R33 Gts25t S2: 65840-26U00
Looking at about $255 ea for the ones above, based on an order quantity of 6.
Once I've got an idea on the pricing of the GT-R ones, I'll be able to give you a more accurate idea on the breakdown for each."
And that's way better than the $900 I was quoted for one from another business - quantity and surface freight working for us!!!!
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
