An easy way to remove badges and stickers is to use a hairdryer... heat them up a little, then pull them off slowly. You then remove the residue with a little bit of methylated spirits, wash, then polish.
You won't be able to tell that the sticker was there in the first place unless your paint has faded noticeably (paint under the sticker will not have faded as much).
wil..
My R33 S1 didn't come with a sticker at the back but it came with a gold badge instead.
I guess it is not from the factory, but it gives it that little bit of prestige hehe.
Gold badge looks good on the blk line.
Coupe only got a sticker.... while 4door sedan gets the badge. Your gold one might be from the 4 door, either that or aftermarket gold one - cos on 4 door I've seen silver badge only not gold.
There's a way to remove sticker without marks is to clean it afterwards and buff it out, maybe cut and polish will do.
Have you had an experienced panel beater have a look at your car? You might be surprised how easy they can spot and point out proof of respray on things that would normally be missed by common people like us... A panel beater showed the proof on mine, I was shocked as I never paid attention on that part until he pointed some little details of previous respray job. However he praised that it is a good quality repair, so it should be ok. :rofl:
Are you saying that every R33 that doesn't have a GTS-T sticker on the back has been resprayed or had an accident. That's a huge call mate I think your jumping to a conclusion. I guess theres other reasons why;
Maybe some didn't come out with them.
Maybe owners removed them.
Maybe stickers were an option when buying?
i was contemplating removing mine but if people are going to jump to the conclusion it has been resprayed or accident damage i might think again. I dont see how people can just automatically assume though if the car doesnt have a sticker its a repair job ???
I never concluded that way, I only ever said "could have been" resprayed, I never say that every R33 without boot sticker IS definitely 100% a respray. It suggest a possibility only. owners can remove them, but if people thinking towards respray then it is because of majority of cases are caused by respray - as people normally don't bother sourcing another sticker after respray. I don't think R33 came out of the factory without badges or boot sticker, it should be standard issue.
And to add to that... my car IS a respray job, and it does have stickers on.
even got the side Skyline strip which looks like an option in Japan that the resprayer even masked off, causing rough edges around the stripe sticker.
If you're in VIC and coming to any future cruises, I'll show you the respray job on my car. That is, if I haven't done another full respray on the car myself before we meet.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
