An easy way to remove badges and stickers is to use a hairdryer... heat them up a little, then pull them off slowly. You then remove the residue with a little bit of methylated spirits, wash, then polish.
You won't be able to tell that the sticker was there in the first place unless your paint has faded noticeably (paint under the sticker will not have faded as much).
wil..
My R33 S1 didn't come with a sticker at the back but it came with a gold badge instead.
I guess it is not from the factory, but it gives it that little bit of prestige hehe.
Gold badge looks good on the blk line.
Coupe only got a sticker.... while 4door sedan gets the badge. Your gold one might be from the 4 door, either that or aftermarket gold one - cos on 4 door I've seen silver badge only not gold.
There's a way to remove sticker without marks is to clean it afterwards and buff it out, maybe cut and polish will do.
Have you had an experienced panel beater have a look at your car? You might be surprised how easy they can spot and point out proof of respray on things that would normally be missed by common people like us... A panel beater showed the proof on mine, I was shocked as I never paid attention on that part until he pointed some little details of previous respray job. However he praised that it is a good quality repair, so it should be ok. :rofl:
Are you saying that every R33 that doesn't have a GTS-T sticker on the back has been resprayed or had an accident. That's a huge call mate I think your jumping to a conclusion. I guess theres other reasons why;
Maybe some didn't come out with them.
Maybe owners removed them.
Maybe stickers were an option when buying?
i was contemplating removing mine but if people are going to jump to the conclusion it has been resprayed or accident damage i might think again. I dont see how people can just automatically assume though if the car doesnt have a sticker its a repair job ???
I never concluded that way, I only ever said "could have been" resprayed, I never say that every R33 without boot sticker IS definitely 100% a respray. It suggest a possibility only. owners can remove them, but if people thinking towards respray then it is because of majority of cases are caused by respray - as people normally don't bother sourcing another sticker after respray. I don't think R33 came out of the factory without badges or boot sticker, it should be standard issue.
And to add to that... my car IS a respray job, and it does have stickers on.
even got the side Skyline strip which looks like an option in Japan that the resprayer even masked off, causing rough edges around the stripe sticker.
If you're in VIC and coming to any future cruises, I'll show you the respray job on my car. That is, if I haven't done another full respray on the car myself before we meet.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
