Australia is fixed, yaaayyy
Oh wait, we need a new scape goat now... Bill shorten? James Hird?
I never said anything was different... just that TA's gaffes are gone
She was clearly just making light of her previous 'drama'.
f*** sake, people
don't think many blokes would turn down mel for a drink lets face it.
Not to hark back to the 50's but if they want her to be taken more seriously perhaps those fancy dresses she wears on the sideline should be substituted with a more professional image
Edited by alr33x
  • Like 1
that was so scripted it's not funny.
just to get people to talk about it.
smart Publicity department.
Top Fuel drags this weekend... looking forward to it. $35? thats only $10 extra than watching the street drags on a friday night (which is a joke).
never been to the drags. hopefully it doesnt get boring.
http://calderparkdragracing.com.au/images/stories/2016/2016_01_23_24_AustralianNationalsCalder_ScheduleV2.pdf
I'll be going on the sunday I think with the mrs cos she's working sat - she's a top fuel virgin too.. shits intense!
Just dont stand in the wind where the fumes are going from them idling on the start line, da eyes burn, goggles do nothingggg.
Edited by UNR33L
You wont need ear plugs it aint that bad, only go for a few seconds anyway
Old F1 cars probably louder / more ear damaging
fair enough. old F1 cars at sandown historic had mufflers fitted. never been to actual modern F1s
im trying to find a video form the Simpsons when Smithers gets a job at the dragstrip.
Its going to be motorised mayhem, mayhem MAYHEM!!
(there used to be one on youtube, but i cant find it).
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
