Australia is fixed, yaaayyy
Oh wait, we need a new scape goat now... Bill shorten? James Hird?
I never said anything was different... just that TA's gaffes are gone
She was clearly just making light of her previous 'drama'.
f*** sake, people
don't think many blokes would turn down mel for a drink lets face it.
Not to hark back to the 50's but if they want her to be taken more seriously perhaps those fancy dresses she wears on the sideline should be substituted with a more professional image
Edited by alr33x
  • Like 1
that was so scripted it's not funny.
just to get people to talk about it.
smart Publicity department.
Top Fuel drags this weekend... looking forward to it. $35? thats only $10 extra than watching the street drags on a friday night (which is a joke).
never been to the drags. hopefully it doesnt get boring.
http://calderparkdragracing.com.au/images/stories/2016/2016_01_23_24_AustralianNationalsCalder_ScheduleV2.pdf
I'll be going on the sunday I think with the mrs cos she's working sat - she's a top fuel virgin too.. shits intense!
Just dont stand in the wind where the fumes are going from them idling on the start line, da eyes burn, goggles do nothingggg.
Edited by UNR33L
You wont need ear plugs it aint that bad, only go for a few seconds anyway
Old F1 cars probably louder / more ear damaging
fair enough. old F1 cars at sandown historic had mufflers fitted. never been to actual modern F1s
im trying to find a video form the Simpsons when Smithers gets a job at the dragstrip.
Its going to be motorised mayhem, mayhem MAYHEM!!
(there used to be one on youtube, but i cant find it).
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
