Just did the Toyota Japan factory tour and museum.
Saw Lexus's and Toyota's being assembled on same production line with same people / tools.
I want a Toyota now....
inb4 Al sells his Lexus
Cos it's made in the same place? couldn't care less. Toyota aren't the only ones to share parts across makes & models. Not to mention why wouldn't it be same people & tools lol Edited by alr33x
Cos it's made in the same place? couldn't care less. Toyota aren't the only ones to put different badges on the exact same cars. Not to mention why wouldn't it be same people & tools lol
Fyp
of the current models, none in AU that I am aware of apart from the "not a landcruiser"...
historically a lot of the "lexus" cars we get are just JDM toyota models with a lexus badge and a bullshit price tacked on...
soarer and celcior would be easy examples but there are many more.
Nissan do it too with the infinity range
Soo like 20 years ago...
$3-4k on wheels and $400 on tyres
http://www.sau.com.au/forums/topic/465076-17-volk-rays-te37-original-tyres-immaculate-condition/
Because AD08Rs won't get you cred at the hardpark meets
why. there is noting you can do with 1000 hp
except break cars.
i was hoping there would be like a GTR graveyard area at Sydney dragway on the weekend.
if you want mega hp, just get an XR6 turbo or something.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
