Just did the Toyota Japan factory tour and museum.
Saw Lexus's and Toyota's being assembled on same production line with same people / tools.
I want a Toyota now....
inb4 Al sells his Lexus
Cos it's made in the same place? couldn't care less. Toyota aren't the only ones to share parts across makes & models. Not to mention why wouldn't it be same people & tools lol Edited by alr33x
Cos it's made in the same place? couldn't care less. Toyota aren't the only ones to put different badges on the exact same cars. Not to mention why wouldn't it be same people & tools lol
Fyp
of the current models, none in AU that I am aware of apart from the "not a landcruiser"...
historically a lot of the "lexus" cars we get are just JDM toyota models with a lexus badge and a bullshit price tacked on...
soarer and celcior would be easy examples but there are many more.
Nissan do it too with the infinity range
Soo like 20 years ago...
$3-4k on wheels and $400 on tyres
http://www.sau.com.au/forums/topic/465076-17-volk-rays-te37-original-tyres-immaculate-condition/
Because AD08Rs won't get you cred at the hardpark meets
why. there is noting you can do with 1000 hp
except break cars.
i was hoping there would be like a GTR graveyard area at Sydney dragway on the weekend.
if you want mega hp, just get an XR6 turbo or something.
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
