martin, hook a brother up.
start bringing in roids or something. dezz and birds can distribute. none of this legit sharemarket shit. VWL goin places. then we can all buy yakuza cars and be conspicuous.
When I was in Brazil all this stuff was for sale direct from Pharmacy's no scripts or anything.
they would have signs out the front with a list of what they had in stock, roids, viagra, oxy the works.
Perfect for your middle aged american there on his sex trip.
Dezz you still riding brah?
Track only still? I been just doing supermoto.. not getting out as much as I'd like tho as usual with bikes :(
I still own a bike, haven't done a track day since February I think it was.. Set a Pb after having not ridden in 6 months though so not all bad
Yer I went on Sunday, was sick as
Dem 5 person backflips from the crowd lol, I spoke to a mate that saw the Saturday one.. they did the same thing with the girl on the front etc.. made us think it was a bit staged.
I reckon it was
I can't see the liability getting away with it and the dude on the very back on the night I went, shoved himself of it before they landed - looked way too intentional
How to hack into own super account and use money for car parts?
this.
im sure one day itll come in handy...
or market will crash and lose majority of it.
I knew older people who had been putting away extra over years and had it sitting in what a super fund would consider "slightly risky" stocks. 2008-2009 market crash or whatever, $650,000 gone from some super accounts. good times.
SO most dairy farms get paid in part with stocks of the dairy they supply which for most is their retirement. (along with selling the farm)
They cannot sell until the end their contract with the dairy.
The largest Dairy company in the area I grew up is Murray Goulburn
ASX: MGC
check the 3 month/1 year of it.
as one of dad's mates put it, so that's what loosing 650K in one day feels like.
and his retirement is on hold for another 5-10 years.
I reckon it was
Don't they put the girl up the front because she is lighter though?
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
