What were you lads saying about RB20 being perfectly good boxes and no need for RB25 boxes??
Lol!
Got another 20 box installed a new clutch and fixed the old 20 box and was still cheaper than a 25!
  • Like 1
Settle down brah, he lost reverse gear
I hear this nearly as much as I hear about centerline.
his work is varies between perfect or completely shocking.
was looking at using him as close to my place when I got the S14, but the stories were too varied.
Sam cops an unfair rep.
His customers use nothing but the cheapest China parts and all drift 24/7 then blame him when the shit breaks.
He knows what he's doing. It's just the nature of the beast being the cheap drift tuner in the west
On the contrary, I used nothing but top brand name parts on my car.. So your point is invalid in my case.
He was also responsible for blowing up a former vwl members engine. No risk of slander as he had to pay for it to be rebuilt.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
