i dont have a spare few grand to drop on this, so i might just start a go fund me. cause you know, others will get to look at and appreciate my car.
http://page18.auctions.yahoo.co.jp/jp/auction/w85837412
whoops, wrong link. what i was referring to:
http://page22.auctions.yahoo.co.jp/jp/auction/l363476344
I grabbed a couple of brochures because there are so many optional extras for Y34 and you just never know what was available. it also confirmed a few items I had were genuine factory fitted or even dealership fitted. And cause im a top bloke, I scan them and share them with others for when they are trawling the auction houses for an example they want.
I just wish they were allowed at events that I attend... Current they're not allowed at CAMS Events, which sucks...
You could use it to capture your mates breaking bones on super motos though.
  • Like 1
Don't see how they could stop you, sit outside the gates and fly it over into sandown and start filming some cars dont get too close and i'm sure no one will stop ya? or sit in the carpark and fly it over lol
Edited by UNR33L
Drone's, not GoPros.
http://www.cams.com.au/media/news/latest-news/new-cams-policy-clarifies-use-of-drones-at-motor-sport-events
Actually it looks like they've now updated their UAV policy (as of February 2016)... but you need to have Civil Aviation Safety Authority certification and 10M Public Liability Insurance.... Yeah, rightio mate...
Noone but commercial aerial photography companies are going to have that...
In the past, CAMS insurance would not cover the event if the incident was caused by a UAV... so if there is an unapproved UAV flying around, the smartest move that the Clark of Course could do is stop racing until the UAV is removed. If a driver gets distracted by a drone over the track and misses his braking marker... then goodbye event coverage.
Would make some mad content though, I'll fly it to sandown from my house just to cancel your event :)
Although they only last for like 20 mins, jokes on me :(
Edited by UNR33L
40 minutes ago, Odium said:
...and then do what? glare at the drone menacingly and hope it goes away?
2 minutes ago, emts said:
it's a disrupter so it blocks signals...drone goes away
Yep, Detects, Tracks, Alerts, and if set it can also bombard the unit with frequencies which will cause it to lose control and crash. (Lots of drones these days have built in defence against confusing signals, and will revert to a hover or return to base).Either way, it's stopped in its tracks.
I'm pretty sure if you are actively using a Blighter AUDS, then breaching the CASA or CAMS policies is going to be the least of your legal issues.
At booze bus in freshly painted GTS-T
Young cop: One long continuous breath etc.
Alright you can go when these cars are clear...*pause* you done any mods to it?
Me: Uh stereo, wheels, lowered it a bit...
Cop: Ah right. Any performance mods or a work in progress?
Me: Nah...not worth it. Not with you guys watching. *smile*
Cop: *laughs*
Me: *drives off sweating*
  • Like 2
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
