I usually try to holiday somewhere bogan aussie aren't
I also have zero interest in going to Thailand
But I mean cos the king just died after 70 years on the throne so they have basically outlawed fun for the foreseeable future
  • Like 1
Sharky said it's all sweet m8. You don't really think they're gonna put a stop on their biggest industries (sex workers and selling beer to bogans) for a year do you?
I'm not really interested in finding out lol
I went to Belarus before I ever went to Bali though so I guess I'm in the minority
  • Like 1
Third world country
Third world cost
Third world hygiene and healthcare
Third world experience
Can be good and bad but you don't always get to choose which parts you get
24 minutes ago, dezz said:
I can vouch for Thailand's hospitals being as good if not better than ours.  We're just so far up ourselves that we think that if someone can't speak English they can't possibly be any good at anything...
You can vouch for the food that poisoned you there too
A lack of English isn't at all my reason for saying that - besides my comment being about Indonesia/Bali - a lack of legal liability is
All those Indos heading home with a case of Aussie belly
I ate street food in Vietnam and Bali too, when in Rome, but no denying the risks are greater in places that don't have health inspectors checking their shit or the potential to get shut down. The holidays are cheap; there has to be a trade off somewhere.
chicken kebab off a bike vendor in Viet.
as in the rotation of the chick skewer was linked to the bike pedals.
that was my balliest move.
on another trip ate same as co worker on everything but last night, he got salad with meal I had chips.
he ended up in hospital on a drip, I ended up at a bar with a bunch of locals.
when you can see black flecks in the water, stick with beer and deep fried shit.
got to Malaysia yesterday and first thoughts is it's up with Hong Kong as fav asian place, really liking it.
Just now, Birds said:
Bali over Vietnam
Really
I guess they don't have Bintang singlets in Vietnam
People were nicer, don't get me wrong the hotel staff etc were fine, it's the random taxi driver / people on the street that shitted me in Vietnam
I mean Kuta wasn't that good in Bali but other places were decent I thought, maybe it's because everyone told me Vietnam is so good and I had high expectations
  • Like 1
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
