1 hour ago, Leroy Peterson said:
Or you could be lame and just accumulate and then leave a sell order for like 3 months at a ludacris value just waiting for it... Im sure there are lots of people who do that
Nothing wrong with this strat; it's medium to long term holding and pretty much what I did to make the first significant chunk of profit from ol 88e. Though with significant enough jumps, you tend to care not for queuing up an order well in advance for the sake of an extra couple hundred dollars when you can just sell to the current buy queue.
Queuing up a sell order is IMO a better strat for short termers and day traders as that one pip of 0.1 cents is more often than not your entire/only profit. With 270,000 shares that's $270 minus $40 brokerage = $230 profit, from investing $10k @ 3.6 cents.
You should follow me on a short term trade sometime Leroy...be interesting if you run into my luck or dezztroy it.
This is how a motorbike should sound:
like a small 4 cyl sports car.
Also think ive narrowed down the pulsar issue... i think the now-independant crank trigger and cam trigger are out of sync. now sure how or why. CAS disc is firmly in place, may need to get tuner to check that they're lined up correctly. After sitting untouched for 2 weeks, it started first time... but yet after that it just cranks forever. I'm just shitty i gotta organise and pay for a tow truck when it really should never have left the workshop...
1 hour ago, Daz said:
You got at least another 3 month wait lol
Probably
Head is back though, which he's porting and polishing now
So machinist isn't an excuse anymore haha
Should see the fuel system he's putting in the 34R :O
9 hours ago, Birds said:
Probably
So that was just the first excuse lol
hoping to see his GTR on the hwy by 2020
47 minutes ago, Leroy Peterson said:
Pffft polishing isn't worth the time or money. Sounds like an excuse to keep your motor disassembled for another month
Is the car going to be tuned on Barry's dyno?
Using work on it as an excuse not to do work on it?
Barry doesn't have a dyno, but it'll be tuned by his usual tuner, cause I like the tuner round there
24 minutes ago, Leroy Peterson said:
Barrys workshop has a dyno doesnt it? Cihan still tuning or is he still part time?
Nah
Shop next door to his does, but he doesn't use them
Yeah Cihan is still tuning to my knowledge
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
    • Not yet quite as bad as what we've seen a Jim Berry clutch do in an R32 GTR though when it decided to cut a chassis rail in half... Still very very gnarly and a great reason to avoid.
