Still have some test driving to do once I sell my car, some guy meant to be coming around tonight to view my car for the 2nd time so we'll see.
I like the Focus RS + scoobies, Audi S3, Merc too but too much $$
Scrap that, guy messaged me and said he wants a car that hasn't been modified at all (my car just has an exhaust & tint basically..) back to square one again :D
So out of 5 guys I've had look, 4 said too modified yet it's all stated in the ad with pictures. People are pretty dumb
Edited by UNR33L
https://www.carsales.com.au/private/details/Abarth-695-2015/SSE-AD-4951364/?Cr=0
$65k brand new. $80k with all the extras. apparently $125k now... not sure if it will sell in a hurry, somehow i doubt anyone in Aus will pay over $100k for it, but there ya go. Apparently this model sold out super quickly in europe. who da thunk.
0-100 in 5.9secs claimed. for that kind of money you could get AMG45.
Yeah that wont sell for that amount of doll hairs.
I think they sold 50 of them in Aus, so it's not like nobody wanted them...
Theres a Honda S660 in NSW for sale. $33k.
A little bit more and you can get an Abarth 124. Turbo 1.6L convertible without mid engine hassles. Obviously not as cool and less Street cred
How you know the seller is a tool: they are offering numberplates 695-500 for $5k extra, when selling the car without would render them worthless.
Don't know why people think rare suddenly means valuable. Rare + desirable makes valuable. It would be a fun car but only some Fiat mad rich guy would see value in that...and who knows...there may be one out there, like there is with Alfa Romeo nutjobs.
But even non sporty fiat 500's are selling for $50k. It's crazy. I just don't get it. They're tall, which takes away the appeal of a hot hatch, so it just becomes retro AWD small car.
Whatevs. I'd have one.
So I could sell it.
So I could sell it.
European version of kei cars?
I think Volkswagen dominate the hot hatch market because they got the formula right: reasonably priced, practical, small, decent looking, quick. Power is missing from a lot of so called hot hatches or flagship/sport model small cars. The AMG A45 is more popular than it should be in this segment because it's one of the quickest. Hyundai Veloster, Astra SRi, Toyota 86, MX5 are all fun cars to drive except in a straight line. There is enough price gap that if they came with a decent bit of grunt they would walk all over the Europeans. I mean, how hard would it have been for Toyota to put a turbo 2.0 in the 86 and who wouldn't pay a 6-7k premium for it when there was/is 8k difference between base and GTS models anyway?
50 minutes ago, Leroy Peterson said:
I do like the Abarth 124.
Wait for plug-in ecu, exhaust, hiflow turbo, add boost, wheels, maybe a diff.
Seems a better prospect than the MX5, at least for a base to establish decent power. MX5 roadster has great looks but 124 looks bigger and classier in pics.
30 minutes ago, UNR33L said:
Probably what I'd upgrade to after offloading 33R to an American
Seem less special the cheaper they get though
How would you cope with only 357kw?
  • Like 1
f**k GTRs. Especially the R35.
I got a steering wheel setup at home if I wanted to play a playstation
Yeah, it's insane with the amount of people who don't bother reading the ad before going further.
It's 2017 mate, no need for plug in ecus. Flash the f**k out of it instead.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
