Who idea was the reverse staggered cams
Cheers
Darren
What do you mean by reverse staggered?
Tomei (For want of a different option) offer the following:
Poncam A :260 inlet and 252 exhaust at 9.15mm lift.
Poncam B: 260 inlet and 260 exhaust at 9.15mm lift.
I have a 256 inlet and a 252 exhaust.
Upgrade option on the inlet side appear to be to go an extra 4 degrees and more lift picking one of 9.15, 10.25 and 10.80.
On the exhaust side the increments are in four degrees also although I didn’t look at the lift.
Inlet 256 degree 9.25mm lift. Opens TDC. Closes 41 degrees ABDC. For 221 degrees duration at 50 thou valve lift.
Inlet 260 degrees 9.15mm lift. Opens 1 degree ATDC. Closes 43 degrees ABDC. For 222 degrees duration at 50 thou valve lift.
Inlet 260 degrees 10.25 lift. Opens TDC. Closes 43 degrees ABDC for 223 degrees duration at 50 thou valve lift.
Inlet 260 degrees 10.80 lift. Opens 1 degree BTDC. Closes 41 degrees ABDC for 222 degrees duration at 50 thou valve lift.
Exhaust 252 degrees 9.15mm lift. Opens 42 degrees BBDC. Closes 8 degrees BTDC for 214 degrees duration at 50 thou valve lift.
Exhaust 256 degrees 9.25mm lift. Opens 46 degrees BBDC. Closes 7 degrees BTDC for 219 degrees duration at 50 thou valve lift.
Exhaust 260 degrees 9.15mm lift. Opens 47 degrees BBDC. Closes 3 degrees BTDC for 224 degrees duration at 50 thou valve lift.
Collapsed mufflers, cat....
This seems the obvious and first area to check. But there seems to have been a lot of effort concentrated on boost control and cam timing. This brought about bottom end improvements, pointing to decent outcomes. Then comments/suggestions drift quickly into using bigger cams which are effectively going to simply shift the curves to the right and sacrifice low/mid range.
The original point of the thread was a reasonably low peak power number for the general engine spec.
The torque curves shown in this thread show something that hits a peak and then just falls away.
Troy's suggestion is where the investigation and power hunt should have started, and does not appear to have been addressed. Disregard whether its a quiet or loud exhaust system. Eliminate the muffler/s and cat, do a trial run on the dyno and establish for certain just how much they are holding things back. Low cost, low effort test. And you can then make an informed decision on what to do.
Many instances where old/collapsing cat/mufflers are choking flow, and also where there are hidden neck-downs to quieten down flash name brand Jap exhaust systems.
  • Like 1
(New) result seems fine to me, he's not on e85 and it's a conservative boost level with cams geared at response over power.
My results are similar boost but on 260/260 + e85/hub dyno and your 70hp ahead at 4000rpm, but only 40hp behind at peak power.
Throw some more boost and some jungle juice if your chasing more outright power IMO
Cams are actually set to chase powahs.
Wish I could get a chart of yours on 98 but nevermind.
Not sure how much more boost there is the controller is at 82% or thereabouts something just over 20lb.
Our R32 GTR had lost power before we pulled it off the road for a new engine build.
The other night i was dropping the exhaust system to remove the rear heat shields so i could drill holes to bolt a battery box down in the boot area.
Center muffler was collapsed, it was a 3.5" system, clogged down to a 2" (or less) system.......never would have guessed it without looking.
I made the same as you did on 98 at 18psi with smaller turbos and standard cams.
Do you have a dyno sheet to share?
The one in your build shows less power @ more boost compared to djr81s 2nd dyno sheet.
6kw (10hp) difference is f**k all and between a -9 and a -5 setup there should be a lot more then that,
As for cams being "too small" if someone can use a 260° in a 3.2 and make 475kw (645hp) why do you need bigger in a 2.6 when you aren't even making 375kw (500hp) yet
As has been said by multiple people, give up on cams and look else where
I dunno maybe a 32 has a very slightly longer stroke than a 26 and therefore doesnt need a long duration cam.
What I am trying to reconcile is the following (In no particular order).
Why the thing appears to have so much torque in the midrange when the -5 turbos arent known for this.
If the exhaust is collapsed (And yes at some stage I will get it checked) how does this fit up with it holding the 20lb boost in the top end - would it not struggle there?
How to differentiate between the theoretical changes for each of the cams, so what would a larger inlet do in this circumstance in isolation. Same question for the exhaust cam.
Oops must have been e85 results. Haha
But here you go for direct comparo. He says around 20 pound and this was 20 pound 98 and 3 years ago.
Cam Gears in and dialled up
Blue line before, Green line after
Hence why I say get it on a dyno. If he has -5's on a built motor then stop messing around.
  • Like 1
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
