Easiest way is to tap a thread behind the actuator on the transfer case and use a bolt to pre load it.
Expensive way is the t case mod by changing the plates.
i love how this post give all the right answers and was completely ignored
Yes i agree that the post has some good and bad idea. But its intresting to see the ideas that we all have. Some are not practical at all but opens the door to understanding peoples point of views. Even though some makes no sense. Kind of like on any topic. Some will always sound crazy.
But here what happened to me.so far i changed the whole attessa pump. And man. I cant see a difference now between reaction time from my r33 gtr to this gts4. All i have now is traction. And yes all i do is drag race, i know lost of the guys here circuit race but some if not lost of things are common. I cant believe the difference this attessa pump made. When i was bleeding it up i noticed the difference right away. The manner in which the pump sounds and the pressure on the line. Now when i drive if i go on the gas a bit and bring in just a little bit of boost the front torque split gauge starts to move up to about 15% and now my 4wd light stays off on start up every time. Before it would come on. Then id have to stop cut the car off and restart it.
From the r33 to r32 i can without a doubt mension tye difference. First the r33 gtr is more relaxed for exsample. R32 whiles driving tends to always apply the front wheels on the r33 gtr this doesn't happen unless there is a slip condition.
Im still going to rebuild my transfercase and when these driven and drive plates come from greenline. (Much thanks there guys) next im working on have the manual engagement system worked out, but im going to install it in my r32 gtr. (Bare wit me it get confusing because i have a few cars i mess with.)
This gts4 chassis i experiment wit.
Thanks for all the ideas guys. Keep them coming. And if anyone has info where i can get a good manual system from please PM me. Thanks.
Edited by MJTru
Talk to Robbie at RIPS, they run some sort of manualised system in their drag cars.
You can sort of see it in this vid-
That's Glenn Suckling's R32 which he bought and put one of his 3.2 Nitto engines in.
Lol. No i dont think ill be doing that bolt mod. But i have ordered a set of friction plates and drive disks from greenline.
I hope these guys are for real and i dont have to visit them. After i paid no one is answering my emails. I wouldn't do business with them again.
If the disk do arrive i will rebuild the T-CASE. And try the manual system here is my first part that arrived. Attached photo.
I will get this to work. Im looking for the hydraulic pressure used for full lock on the T case. ???
I was trying to find the pressure from a video by looking at the gauge, but the image isn't clear enough.
Robbie from RIPS has bought the car and is now dragging it. You could try an email - you might get a reply or not?!
http://www.ripsracing.com/
I looked into it, apparently 220psi stock. I was looking to bump that pressure up a bit in the Stagea.
I have done this mod to several track cars I used to work on and feedback was that it worked extremely well.
Something to be aware of though is that for a street car this wouldn't work all that well as it does leave the transfer case prelaoded at all times. You need to get under the car and adjust it as well, though adjustment is very easy given its just a bolt and locking nut.
  • 4 weeks later...
I have finally gotten a set of these disk from rhdjapan. FYI i spoke to mr. Hobbs and had him place the items on there site. (Search by part number) I was really suprised at how fast he got them to me.
This week i will be pulling the box out and ripping it apart (T-case) to replace these friction disks. I cant wait. Then ill focus on doing the manual pump system. I just wish there was a kit out there to buy from a store. If it gets to complicated for me ill just go get the torque split controller.
  • Like 1
Hmm. It was very easy to do. I just didnt change all the seals that most recommend. No leaks so far. I see what most said. Dont add the disk and block the oil drain holes in the friction disks drum.
My mistake was that i didnt soke the disk in oil before installing them. Notice it locked up in 4wd wit no oil. So we didnt want to take it all apart and came up with the idea to take the engagement piston out, then it started to free spin. So we added oil and spin it free hand as well as drowning it in oil making sure we wasted money buying oil and having the whole friction disk area soke in oil. (Dumb). we then measure the clearance and we were at the minimum of .008. Once soked wit oil we still couldn't free spin it by hand. But sure with front wheel resistance it will free spin.???
Here is some photo's
Very simple to do so far.
Edited by MJTru
The old disk were good but just a bit worn. I measured it before disassembling it and it was over .020 inch. Sorry for that. So definitely at .008 its within factory standard.
Damn no one is intrested in this post it seems like. :(
Well i just bought the ETS PRO from fullrace. Cost 660 usd dilivered.
I found some info saying the samething someone said here. I can put it in manual mode and full 4wd lock and let it rip. Then at high speed go 2wd.
Im just trying to think of a way i can get it to go into 2wd automatically???
Brain buster.
Any ideas. ???
Just off the top of my head, you would probably need to run a circuit from your wheel speed sensor circuit to your pump/ controller. Or some setup from the G sensor signal or both. But aren't you using a manual override anyway?
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
