Ive just got a 25det neo running in my stagea, but theres a knocking coming from the intake cam when the vct solenoid isn't open. When its idling up until about 1400rpm you can hear the knocking but when the vct opens, above 1400rpm, the knocking goes away and sounds mint, ive tried replacing the solenoid with another one but to no avail anyone had this before?
https://www.sau.com.au/forums/topic/458930-rb25det-neo-vct-knocking/
So i changed the cam gear with one of a 25de neo, and i noticed that the cam gear was bolted up differently to the original one, the de one was bolted central to the vct and the det was bolted hard one way. I ran it how it was set and was lacking alot of top end and didnt keep pulling at all after 5000rpm, so i moved it the same way hard as the original one and still is lacking top end and it feels like its surging when you put your foot on it? Is it too advanced? Could the cas need adjusting? post-140767-14402025659652_thumb.jpg
not sure if related, but when I did my timing kit and removed the VCT solenoid to take the seals off, I over tightened the VCT using a rattle gun (being lazy of course). Some how I jammed the unit and the car was sluggish down below...
Make sure it's sitting in the right position before torquing it up to spec.
Man, I meant the whole vct unit along with cam gear.
I thought it was kind of obvious.
Changing just the actual gear part is a bit pointless, it's the actual vct actuator part of the car gear assembly that needs to be changed.
I changed the whole unit, not just the outside gear, the knocking has stopped, reading up it sounds like timing, a mechanic mate is bringing his scanner over later and will plug it in, to make sure the timings right
    • The real question is, on some of those wild roads they call highways, how many times did a farmer in an old ute from the early 2000s blaze past you over double lines?   Tassie is a wild and really cool place, and after doing a work related road trip there January of 24, I understand why Targa Tasmania is ran there, and is so tough to do well at! We had a brand new Camry Hybrid that handled quite nicely, and thankfully weren't in an old car, because cresting some of those hills in a 100kmh zone for it to suddenly be like "surprise f**kers, this is a recommended 30kmh hard right turn" wouldn't be pretty. We weren't racing the Camry around, but we weren't slouching in the bends either. But my lord those old farmers know their old clapped out utes, and those roads, as they were absolutely hammering it!   You're also super lucky to make it up to Mt Wellingtong this time of year. It's often road closed with snow/ice! Also, I hope you hit up Salamander Road in Hobart for some insanely good food (I highly recommend the dimly lit Irish pub for a Guiness Pie, or even the bangers and mash!!!)   How long did the Ferry take to get across? I want to do a road trip of Tas on my own time, but I get horrifically sea sick, and I don't want me on the Ferry, just the car 😛
    • So far so good, about 30km on it so far and nothing out of sorts yet thankfully
    • Look at @Kinkstaah's thread on the issue.
    • Hmm not really, I'd say its race car life or modified car life when you make 3 or 4 times the power Nissan designed the car for lol.
    • I'll let others with more breakage chime in, but I can't think of anyone who had a problem with the standard centre plate before they had a problem with the standard gears - the plate generally just gets replaced for safety when the gearset is upgraded. As for the gearsets, its not like they are OK at 600Nm and break at 601. Their longevity is a combination of how much torque you are making and how gentle you are on shifts (or not).
