Hi all,
How are people locking off their ignition advance to set base timing? I've got an inductive pickup timing light with the pickup clipped around the white wire loop at the start of the coil harness (it's at the back near the firewall), but the ECU is constantly varying the timing and it's very difficult to read. How have other people locked it at 15 degrees?
I have tried Conzult's "idle setting" but that doesn't tell me what the timing is set to, and it doesn't seem to be constant. It just seems to adjust the idle speed.
Cheers
DaveB
https://www.sau.com.au/forums/topic/459187-setting-timing-on-25det-neo/
And check the sticker on you bonnet to see what it should be set at. I believe auto and manual base timing is different. And yes unplug TPS and use an old spark plug lead between cyl 1 coilpack and plug.
Well I tried timing from various points and comparing them to the #1 spark plug using an HT-driven timing light, and I can now say for sure that timing off the loop wires shows about 15 degrees more advance than using the #1 spark plug method. I took some pictures if people are interested but I hope this is enough.
Some weirdness I noticed, has anybody ever seen this? With TPS unplugged (thanks owen1r) I loosened all 3 bolts on the CAS sensor, and then rotated until I observed the same timing with the light that the ECU was commanding (in this case 12 degrees). That was fine. But then I would notice that as soon as I tightened just one of the bolts to even finger tight, the timing would change back to like 5 degrees?! The CAS was definitely not rotating, and it would have to rotate a significant amount to make that much difference to the timing. Does anybody know what could be going on there? This is my second CAS too since I replaced it a while ago.
thanks
David
Lots of timing lights (generally the less expensive ones) read double the actual timing from the loop at the back, so if you are seeing 30o you can probably read that as 15o
Interesting to know thanks Duncan. Do you have any suggestion for why it might be changing when I tighten the CAS? I'm a bit worried that the CAS is reading UNDER, and therefore I might have more timing than there should be.
Edited by DaveB
I don't think it's that simple and I wouldn't like to just guess.
If the gun is picking up the leading edge of the current in the loop wire, the amount of dwell is added to the timing reading. It might look like double, bit that's basically just a fluke. It should really pick up on the falling edge of the loop wire to be accurate.
I would still not trust it, a plug lead between coil and plug is best option.
  • Like 1
I compared both and I couldn't find any correlation.
With the inductive pickup timing light, off this wire:
...I measured about 22 degrees:
But with an older style timing light, that connects directly to the spark plug (it has a long spring which fitted into the coilpack), it read about 5 degrees!
  • Like 1
Do some maths. I'm sure it would be able to be calculated back to the dwell of the coil.
I seriously can't be bothered looking I to it further!
It's enough to know to not trust/use the loop, especially without checking it to a lead.
Sure. What I meant to say was, it doesn't look easy like 2 x the spark-measured value or something similar.
  • Like 1
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
