Hey everyone,
My name is Sammy and I bought my first nissan, a 1991 Nissan Skyline GT-R about 5 months ago. I used to own many ae86s after having enough of rust and leaks, i decided to sell them all and move on to something more desirable, which got me here. To briefly describe my technical skills, I'm good at turning a wrench but an amateur at diagnosing.
After driving the vehicle for a few weeks, I noticed that there was a tapping/ knocking noise coming from the engine. The noise is only there when i cold start the engine. After driving the car from about 15 minutes, the noise is COMPLETELY gone.
Here is the video of the sound: https://www.youtube.com/watch?v=TPS5SNXujHc&feature=youtu.be
(sounds exactly how it sounds in the video. I would turn off the bass on the speakers to hear it properly.)
I've had a various tuner shops have a look at the car and noone would give me even a rough estimate of the problem without asking me to rip apart the engine at their shop for $150/hr. So i stopped driving the car and it's been sitting in the driveway for 4 months now.
Although one person told me that my timing belt is too tight and the oil pumps also make that noise sometimes so I have all those parts on order and waiting for them to arrive.
The car is fully stock. No mods whatsoever apart from a quite kakimoto catback.i am using castrol gtx 10w40 conventional engine oil.
Please help
Edited by gotenek
Conventional oil? As in not synthetic?
What oil?
Hard to tell from the video, but I would check valve clearances first, as it is relatively easy.
If it's a death knock, go hard. If the engine wants to doe it will Wether you like it or not.
What oil?
Yes, non-synthetic castrol gtx 10w40.
Pretty sure don't have forged pistons lol. I dont think the cam covers were ever removed when i replaced the rubber just a few weeks ago.
I just changed the oil to fully synthetic 5W40 for the hell of it. The noise was still there.
So I grabbed a long screwdriver and started poking around the top of the engine with my ear to the other other of the screwdriver.
The noise was about 10% louder than you can hear without the screwdriver on the whole area of the cam covers.
The noise was about 3X louder when I put the screwdriver on top of the top timing cover. I have a plastic clear timing cover ( just want to mention it)
Thus, I'm assuming the noise is coming from somewhere in the timing belt area. Can tensioners make that kinda knocking/tapping noise? Or perhaps the oil pump?
Use the screw driver trick to the ear along the top of the cam cover and front cover.
Also do it to your injectors and around the exhaust manifold (in case you have a seriously odd leak making the sound and heat closes the leak).
Take out your coil packs and check to see if your spark plugs are tight.
doo doo, Unfortunately I'm located in Canada. Thanks for the offer.
I'm going to be pulling the engine and inspect a few things, especially in the head - the cam cover caps. Thanks for all the help everyone.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
