Ive owned 4 r32 skylines and on one of them there was a square brake light on the top of the windscreen. I think it is better since its an extra light that only comes on when you are braking because if you got your lights on, only the 4 round lights light up both when you are braking and when you are not braking, so people who are not focusing on the road will be able to tell that you are braking cause of the extra light that lights up, because i had alot of close calls with people behind me nearly rear ending me. Is it an oem part? i cant find any anywhere. If anyone can point me in the right direction that'll be swell :worship:
It could be that the R32 with that third brake light was Australian delivered. Does that sound right? The ADM ones had some changes that the JDM ones didn't.
My wife had a Corona as her first car that had two additional brake lights in the top of the back window. They were just generic universal ones from Repco.
Hope that helps.
Oh, then I must be way off with the ADM thing.
maybe the GTR's need them because there is no light on the gtr spoiler but the gtst spoiler has a light
Mine is a Hella I think. Or maybe Narva.
I think they get installed as part of compliance.
have u got any pics?
Edited by IM-32-FK
My GTS-T has a narva/hella item which I'm assuming was also installed during compliance, it's got the GTR spoiler (no lights)
I'm pretty sure it's an ADR/compliance law rather than a factory option / nissan part
Alrighty, i checked ebay and there are 2 'hella matrix' lights
this one: http://tinyurl.com/pkhy42c and this one: http://tinyurl.com/paeqexo
Im thinking the 1st one. Also what brand are these and are they guaranteed to sit in nicely on a r32 gtst? If anyone knows any more better looking ones then let me know please
thanks :happy:
Edited by IM-32-FK
My one was removed during tinting, and fell off when I stuck it back on (didn't use fresh tape, silly me). So I shoved it in a corner and now it's stuck there lol.
But yeah, looks like your ones linked but older (non LED I think).
Brake lights are much brighter than tail lights (something like 21W v 5W), so any competent driver following would be able to tell whether or not you were braking. For people not focusing on the road, it really won't matter how many brake lights you have.
That said, what I did with my 32 (doesn't have that stupid eye-level light) is to clip the tail light wire to the inner 2 tail lights, so now I have 2 tail lights and 4 brake lights (I stole the idea from the 240K setup, having seperate tail / brake lights). Much simpler, just as effective.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
